pls solve this error
Old   January 31, 2009, 01:05
Default pls solve this error
chandrasekhar
hi
while solving the wave tank problem i am getting the error like this.can any body help me to solve this
Error message from graphics function Update_Display: Invalid subscreen specification - Subscreen 'bottom' is above 'top' -- Will use (-1, +1, -1, +1) --
problem
thanking you sekhar
Old   January 31, 2009, 10:03
Default Re: pls solve this error
otd
What software? Which wavetank problem?
Old   February 1, 2009, 00:32
chandrasekhar
hi i am using fluent software. i modelled the water tank using gambit while opening with fluent it was fine .if i display that mesh file i am getting the error like this.
thanking you
nonNewtonian viscosity model mhassani OpenFOAM Programming & Development 5 January 7, 2013 09:27
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
