January 31, 2009, 08:04 |
2d rotary vane pump problem
hai, im tryin to solve a simple 2d rotary vane pump problem..just to see how the moving mesh works .but im not able to solve it and also i used a simple udf for DEFINE-CG_motion.but only the nodes are movin and i knw we have to use face thread.but i dont knw how to use it.plz could you tell me a guide how to solve this problem or if u have any old papers regarding rotary vane pump.plz send it..my mailid hari2savvy@gmail.com. And im not able to get the papers from net i got only handout98.pdf..whch was not helpful..im using fluent by the way thank you hari
February 1, 2009, 17:16 |
Re: 2d rotary vane pump problem
http://www.fluent.com/solutions/automotive/ex239.pdf
http://progdata.umflint.edu/MAZUMDER/Fluent/Fluent%20Tutorial/Multiphase%20flow%20tutorial/pump/vane-pump.pdf |
February 2, 2009, 01:28 |
sir thank you very much ill check and thank you very much for ur help
Display Modes | |
rotary vane pump udf files | R.SRIHARI | Main CFD Forum | 1 | February 27, 2009 10:25 |
problem with pump as source term | hari | FLUENT | 1 | September 19, 2005 12:38 |
Help: axial pump :Iges problem | nithyanand | FLUENT | 5 | February 2, 2005 05:25 |
a problem in pump simulation | feng | CFX | 5 | August 23, 2004 04:21 |
Flow analysis of vane pump | Loganathan | FLUENT | 4 | September 4, 2002 05:51 |
