December 27, 2015, 11:18 |
Closed Geometry
Sagar
Rep Power: 10 |
I wanted to ask that what is exactly meant by closed volume or closed geometry? Say in a cad, there shouldn't be an empty space inside?
December 27, 2015, 12:01 |
Rep Power: 18 |
A better term is watertight. If you placed the geometry in a bucket of water would the interior remain dry or would you have a leak. A closed geometry is one that is watertight.
December 28, 2015, 01:29 |
Sagar
Rep Power: 10 |
So all the extrusions and the lofts that are solid should be closed whereas the surfaces that are not convex would be open(or not closed) geometry, right!
I do not understand the concept why air interactions in softwares like Altair Virtual Wind Tunnel need a closed geometry. They should even be able to simulate the vortices or so in the real car right if it has a not-closed geometry! |
December 28, 2015, 10:04 |
Rep Power: 18 |
Closed geometry is more of a requirement for the mesh generation. You only want mesh where you actually have flow, and unnatural surface concavities (such as between surface patches that don't match up perfectly) tend to break most meshers.
[DesignModeler] Fill tool - grouping the faces of a complicated geometry? | HeikkiT | ANSYS Meshing & Geometry | 8 | July 20, 2016 07:37 |
Export geometry file from ansys mechanical | browns6 | Structural Mechanics | 0 | August 27, 2013 16:19 |
2D geometry to 3D geometry | Sgonzalezg | ANSYS Meshing & Geometry | 11 | April 8, 2011 11:02 |
[snappyHexMesh] Trouble with stl file: surface not closed (snappyHexMesh) | sfalsharif | OpenFOAM Meshing & Mesh Conversion | 3 | April 3, 2011 05:53 |
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry | villier | OpenFOAM Meshing & Mesh Conversion | 17 | June 15, 2010 19:51 |
