Inviscid Flow Low Lift
Old   December 31, 2015, 08:27
Default Inviscid Flow Low Lift
Erdem Eskioglu
ErdemEskioglu is on a distinguished road
I'm analysing an aircraft in FLUENT to compare results with the experimental results. But first, I'm doing the wing only analysis in inviscid model to see if I'm doing right or not.
Profile: NACA 0015
Chord: 0.133 m
Span: 0.54 m
Re: 335000
Model: Inviscid
I am getting lower Lift Coefficients for NACA 0015 Wing at about same reynolds number than the experimental Lift Coefficient.
Isn't it wrong? My model is inviscid so there is no viscous effect no boundary layer and no Lift Loss due to viscosity.
I expected higher Lift Coefficient than experimental in no-stall region at different angle of attacks.
What am I doing wrong. Can you help me?
Best regards,
Erdem
ErdemEskioglu is offline   Reply With Quote
Old   December 31, 2015, 08:37
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Profile: NACA 0015
Chord: 0.133 m
Span: 0.54 m
Re: 335000
Model: Inviscid
Best regards,
Erdem
what do you mean?
FMDenaro is offline   Reply With Quote
Old   December 31, 2015, 08:40
Erdem Eskioglu
My analysis reynolds number = 335000
NACA0015 Experiment results for reynolds number = 360000
My analysis and experimental reynolds number are close to each other
Old   December 31, 2015, 09:06
if you use inviscid models, you have no finite Re number!
Old   December 31, 2015, 09:09
Erdem Eskioglu
I know since there is no viscosity. I made an assumption assuming standard air viscosity. What I am trying to say is what should I expect in terms of CL comparison. Is it normal to have lower lift than the real case?
Old   December 31, 2015, 10:41
a rude assumption on the pressure distribution: normal pressure derivative in the BL is almost as the same as in the external flow, that means that the on the airfoil wall at high Re you get the same pressure distribution,
Old   December 31, 2015, 16:54
Erdem Eskioglu
I have lower lift than the experimental about %30 difference.
I did 2D airfoil analysis and had almost same lift with the experimental data.
Problem is 3D wing, what can cause this much difference?
Thanks,
Old   January 1, 2016, 13:39
Kaya Onur Dag
kaya is on a distinguished road
I have no clue about FLUENT
If you're doing inviscid computations, you don't have Reynolds number, or its just infinity. But lets put this aside.
When you do a 3d wing computation, due to the induced wind, tip vortices, induction from the wake, (or what ever you want to call it ) you will never get the same 2d-lift on a 3d wing (unless your AR:aspect ratio=span/chord is infinity). Have you taken this into account while comparing your 3d lift with 2d one?
ps.there usually is a remarkable change in polar curves in between Re 1e5 to Re 1e6. If your measurements were taken at a lower Re, perhaps your 2D inviscid computations wouldn't have matched well.
kaya is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
The lift force coefficient in bubbly flow Kai Yan Main CFD Forum 1 November 4, 2008 13:54
inviscid Sylvain FLUENT 6 October 30, 2005 13:58
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
