Pressure-projection scheme for a lid-driven cavity |
January 6, 2016, 15:58 |
SD
Rep Power: 10 |
Hi everyone
I was mixed by one problem for some time and wonder if there is someone who can cast some light on my head. I'm trying to implement a pressure-projection code for the case of a lid-driven cavity. But I think my code is wrong and I don't know why. The results I get are false. (you can see the attached picture) I don't know if it is a boundary condition problem, if something is missing in my method, if the parameters are wrong or if it's simply a programming error (I have checked many times ). I'm almost sure it is a simple issue and if someone who is a bit experienced with pressure projection method see this, it could be easy to point out the issue. I'm a CFD begginer so I apologize by advance if it is a trivial issue, but I have been stucked for many hours and I really want this program to work You can find my program attached in this topic, if someone find an error or some missing calculus, I will be really grateful Thank you in advance ! See you. My code works as follows : First step : Intermediate velocity Momentum : Intermediate velocity : Second step : Fractional step, solution of the poisson equation 1. Compute the divergence of the velocity field (to have RHS) and so Before solving this equation, we need to compute the Right Hand Side. 2. Solve the poisson equation After computing the RHS, we need to solve this poisson equation iteratively. I use a S.O.R method : So So we compute the pressure this way : Third step : Velocity field update The pressure gradient is calculated as a forward finite difference. And loop to the next time step. You can see my code attached Thank you in advance ! |
January 6, 2016, 16:54 |
Filippo Maria Denaro
Rep Power: 71 |
what about the BC.s for the pressure equation?
are you using staggered or colocated grid arrangement? have you checked the divergence-free constraint in each cell after the correction? Then, provide a velocity plot |
January 6, 2016, 19:57 |
SD
Rep Power: 10 |
Hi!
Thank you for your answer. I think it is a collocated grid I'm using in the program. The BC for pressure are Neumann type, but actually I think the problem might be here. Here is the code I use for computing the pressure, I didn't know how to implement the BC. Code:
do j=2,jmax-1 do i=2,imax-1 as=w/(Dy*Dy) aw=w/(Dx*Dx) ae=w/(Dx*Dx) an=w/(Dy*Dy) ap=2*((1/(Dx*Dx))+(1/(Dy*Dy))) p(i,j)=(1-w)*p(i,j)+(1/ap)*(as*p(i,j-1)+aw*p(i-1,j)+ae*p(i+1,j)+& an*p(i,j+1)-w*RHS(i,j)) end do end do !Neumann conditions do i=1,imax do j=1,jmax !Bottom p(i,1)=(1-w)*p(i,j)+(1/ap)*(as*p(i,j)+aw*p(i-1,j)+ae*p(i+1,j)+& an*p(i,j+1)-w*RHS(i,j)) !Top p(i,jmax)=(1-w)*p(i,j)+(1/ap)*(as*p(i,j-1)+aw*p(i-1,j)+ae*p(i+1,j)+& an*p(i,j)-w*RHS(i,j)) !Left p(1,j)=(1-w)*p(i,j)+(1/ap)*(as*p(i,j-1)+aw*p(i,j)+ae*p(i+1,j)+& an*p(i,j+1)-w*RHS(i,j)) !Right p(imax,j)=(1-w)*p(i,j)+(1/ap)*(as*p(i,j-1)+aw*p(i-1,j)+ae*p(i,j)+& an*p(i,j+1)-w*RHS(i,j)) end do end do I'm not checking the divergence free constraint, what do you mean by that ? |
January 7, 2016, 04:35 |
Rep Power: 71 |
I suggest a deeper study of the method, the original paper in JCP is a good starting point
http://www.sciencedirect.com/science...21999185901482 |
January 7, 2016, 04:58 |
Arjun
Rep Power: 34 |
The main problem that I see in your code is that you dont show us how you calculate divergence for velocity field.
For collocated method to work, the velocity at face that you use for divergence has two contribution one from the interpolated velocity and one from rhie and chow dissipation term (which is function of pressure and AP). Also if you did so based on Ap you used then you still have problem because from it you can not derive the pressure equation you use. Hint: the pressure equation you use you will get when your Ap has only time contribution and nothing else. But i guess you use different Ap for interpolation. Last make sure the solver is handling all neumann condition too. |
January 7, 2016, 05:10 |
#6 | |
Rep Power: 71 |
the way in which the code is written is not correct... the Neumann condition must change both the matrix entries and the known term (RHS of the Poisson equation). The first "do" cycles must be rewritten differently for nodes adjacent to the boundaries and the second "do" cycles can be eliminated. |
January 8, 2016, 11:12 |
SD
Rep Power: 10 |
Hi!
Thank you everyone These Neumann BC are really annoying me, I think my approach is wrong. For the problem to be easier, I use the Jacobi method instead of a SOR. I use the formulas which I found here : http://demonstrations.wolfram.com/So...ferentMethods/ (I have a uniform grid spacing) For the no BC cells : For the BC cells : My code is the following : p represent p(k+1) and pold represent p(k) Code:
!Solve pressure poisson iteratively rP=11 iterationPP=1 p(:,:)=0 do while ((iterationPP < 200).and.(rP>0.0000001)) iterationPP=iterationPP+1 pold=p !Neumann Boudary do i=2,imax-1 !Left p(i,1)=0.25*(2*pold(i,2)+pold(i-1,1)+pold(i+1,1)-Dx*Dy*RHS(i,1)) !Right p(i,imax)=0.25*(2*pold(i,imax-1)+pold(i-1,imax)+pold(i+1,imax)-& Dx*Dy*RHS(i,imax)) end do do j=2,jmax-1 !Top p(1,j)=0.25*(2*pold(2,j)+pold(1,j-1)+pold(1,j+1)-Dy*Dy*RHS(1,j)) !Bottom p(imax,j)=0.25*(2*pold(imax-1,j)+pold(imax,j-1)+pold(imax,j+1)-& Dy*Dy*RHS(imax,j)) end do !Jacobi iteration for the cells in the center do j=2,jmax-1 do i=2,imax-1 p(i,j)=0.25*(pold(i-1,j)+pold(i+1,j)+pold(i,j-1)+pold(i,j+1)-& Dx*Dy*RHS(i,j)) end do end do !Corners p(1,1)=0.5*(p(1,2)+p(2,1)) !Bot-Left p(1,jmax)=0.5*(p(1,jmax-1)+p(2,jmax)) !Top-Left p(imax,1)=0.5*(p(imax-1,1)+p(imax,2)) !Bot-Right p(imax,jmax)=0.5*(p(imax,jmax-1)+p(imax-1,jmax)) !Top-Right rP=abs(maxval(pold(:,:)-p(:,:))) print *, "rP=", rP end do Thanks Simon |
January 8, 2016, 11:46 |
Rep Power: 71 |
Simple 1d example for the Poisson equation
((dp/dx)i+1/2 - (dp/dx)i-1/2)/h = ((u*)i+1/2 - (u*)i-1/2)/h Neumann BC at i-1/2 dp/dx = u* - un+1 the equation becomes ((dp/dx)i+1/2 )/h = ((u*)i+1/2 - (un+1)i-1/2)/h |
January 9, 2016, 08:52 |
#9 |
Arjun
Rep Power: 34 |
for pure poisson problem your iterative solver shall not work.
November 18, 2017, 02:45 |
SIMPLE algorithm for lid-driven cavity not converging
#10 |
Karthikeyan
Rep Power: 9 |
I have written a code in FORTRAN for solving incompressible steady flow in a lid driven square cavity. I have used a staggered grid formulation; I have used upwind scheme for calculating the convective fluxes at the faces (Fe, Fw, Fn, Fs in the code). I tried playing around with the under-relaxation factors but could not get a converged solution for v velocity. I am attaching my code here. Please provide some suggestions. Code:
program main implicit none integer :: imax, jmax, i, j, iter = 0, it !u_temp and v_temp are the matrices with 2 less columns and 2 less rows than u and v respectively !u_temp and v_temp temporarily store output from gauss-seidel double precision, allocatable :: u(:,:), u_temp(:,:), u_aP(:,:), u_aE(:,:), u_aW(:,:), u_aN(:,:), u_aS(:,:), u_b(:,:) double precision, allocatable :: v(:,:), v_temp(:,:), v_aP(:,:), v_aE(:,:), v_aW(:,:), v_aN(:,:), v_aS(:,:), v_b(:,:) double precision, allocatable :: p(:,:), pprime(:,:), aP(:,:), aE(:,:), aW(:,:), aN(:,:), aS(:,:), b(:,:), psi(:,:), & & d_u(:,:), d_v(:,:), p_temp(:,:) double precision :: Fe, Fw, Fn, Fs, De, Dw, Dn, Ds double precision :: H = 1.0, W = 1.0, del_x, del_y, rho = 1, mu = 0.01 double precision :: U_W = 0.0, U_E = 0.0, V_S = 0.0, V_N = 0.0, U_S, U_N, V_W, V_E double precision :: alpha_u = 0.52, alpha_v = 0.5, alpha_p = 0.01 double precision :: u_residual, v_residual, c_residual, tolerance = 1e-6, temp, r write(*,*),'Enter the number of cells (cells for scalars) required in the x direction' read(*,*), imax write(*,*),'Enter the number of cells (cells for scalars) required in the y direction' read(*,*), jmax del_x = W/imax del_y = H/jmax !diffusion coefficients for calculating coefficients in momentum equation De = mu*del_y/del_x Dw = mu*del_y/del_x Dn = mu*del_x/del_y Ds = mu*del_x/del_y allocate(u(imax+1,jmax), u_temp(2:imax,jmax), u_aP(2:imax,jmax), u_aE(2:imax,jmax), u_aW(2:imax,jmax), & & u_aN(2:imax,jmax), u_aS(2:imax,jmax), u_b(2:imax,jmax), d_u(imax+1,jmax)) allocate(v(imax,jmax+1), v_temp(imax,2:jmax), v_aP(imax,2:jmax), v_aE(imax,2:jmax), v_aW(imax,2:jmax), & & v_aN(imax,2:jmax), v_aS(imax,2:jmax), v_b(imax,2:jmax), d_v(imax,jmax+1)) allocate(p(imax,jmax), pprime(imax,jmax), aP(imax,jmax), aE(imax,jmax), aW(imax,jmax), aN(imax,jmax), & & aS(imax,jmax), b(imax,jmax), psi(imax,jmax), p_temp(imax,jmax)) !initial guess values - p*, u_g, v_g, p' p = 0.0 pprime = 0.0 u = 0.5 v = 0.5 !setting the p' value zero at cell 1 pprime(1,1) = 0.0 !boundary conditions falling at the cell centers of u and v control volumes do j = 1, jmax u(1,j) = U_W u(imax+1,j) = U_E end do do i = 1, imax v(i,1) = V_S v(i,jmax+1) = V_N end do !u BCs which fall on 'v' cell centers and v BCs which fall on 'u' cell centers U_S = 0.0 U_N = 1.0 V_W = 0.0 V_E = 0.0 10 FORMAT('Iteration',T12, 'u-velocity @ (',I3,',',I3,')') 20 FORMAT(I8,T12,F12.6) 30 FORMAT(/'Iteration',T15,'c-residual',T30,'u-residual',T45,'v-residual'/) 40 FORMAT(I5,T15,e12.6,T30,e12.6,T45,e12.6) 50 FORMAT(/'Iteration',T10,'aP',T20,'aE',T30,'aW',T40,'aN',T50,'aS'/) 60 FORMAT(I5,T10,f10.6,T20,f10.6,T30,f10.6,T40,f10.6,T50,f10.6) 70 FORMAT(/I4,T5,I10,T20,'u-error:'e15.6,T55,'u =',T58,f12.6/) 75 FORMAT(/I4,T5,I10,T20,'v-error:'e15.6,T55,'u =',T58,f12.6/) 80 FORMAT(/I4,T5,I10,T20,'p''-error:'e15.6,T55,'u =',T58,f12.6/) open(4, FILE = 'iter vs u_vel.txt') write(4,10),imax/2,jmax/2 open(5, FILE = 'aP_etc_u-vel.xlsx') do iter = iter+1 !coefficients for u momentum equation over u control volumes do j = 1, jmax do i = 2, imax !calculating convective fluxes at the faces of the 'u' control volumes Fe = rho*del_y*(u(i+1,j) + u(i,j))/2 Fw = rho*del_y*(u(i,j) + u(i-1,j))/2 Fs = rho*del_x*(v(i-1,j) + v(i,j))/2 Fn = rho*del_x*(v(i-1,j+1) + v(i,j+1))/2 !adding the pressure gradient terms to b if (j == 1) then u_aE(i,j) = De + max(-Fe,0.0) u_aW(i,j) = Dw + max(Fw,0.0) u_aN(i,j) = Dn + max(-Fn,0.0) u_aS(i,j) = 0 u_aP(i,j) = u_aE(i,j) + u_aW(i,j) + u_aN(i,j) + Fe - Fw + Fn + 2*Ds u_b(i,j) = (2*Ds + Fs)*U_S + (p(i-1,j) - p(i,j))*del_y else if (j == jmax) then u_aE(i,j) = De + max(-Fe,0.0) u_aW(i,j) = Dw + max(Fw,0.0) u_aN(i,j) = 0 u_aS(i,j) = Ds + max(Fs,0.0) u_aP(i,j) = u_aE(i,j) + u_aW(i,j) + u_aS(i,j) + Fe - Fw - Fs + 2*Dn u_b(i,j) = (2*Dn - Fn)*U_N + (p(i-1,j) - p(i,j))*del_y else u_aE(i,j) = De + max(-Fe,0.0) u_aW(i,j) = Dw + max(Fw,0.0) u_aN(i,j) = Dn + max(-Fn,0.0) u_aS(i,j) = Ds + max(Fs,0.0) u_aP(i,j) = u_aE(i,j) + u_aW(i,j) + u_aN(i,j) + u_aS(i,j) + Fe - Fw + Fn - Fs u_b(i,j) = (p(i-1,j) - p(i,j))*del_y end if end do end do !coefficients for v* momentum equation over staggered control volumes for v do j = 2, jmax do i = 1, imax !calculating convective fluxes at the faces of the 'v' control volumes Fe = rho*del_y*(u(i+1,j) + u(i+1,j-1))/2 Fw = rho*del_y*(u(i,j) + u(i,j-1))/2 Fs = rho*del_x*(v(i,j) + v(i,j-1))/2 Fn = rho*del_x*(v(i,j) + v(i,j+1))/2 !adding the pressure gradient terms to b if (i == 1) then v_aE(i,j) = De + max(-Fe,0.0) v_aW(i,j) = 0 v_aN(i,j) = Dn + max(-Fn,0.0) v_aS(i,j) = Ds + max(Fs,0.0) v_aP(i,j) = v_aE(i,j) + v_aN(i,j) + v_aS(i,j) + Fe + Fn - Fs + 2*Dw v_b(i,j) = (2*Dw + Fw)*V_W + (p(i,j-1) - p(i,j))*del_x else if (i == imax) then v_aE(i,j) = 0 v_aW(i,j) = Dw + max(Fw,0.0) v_aN(i,j) = Dn + max(-Fn,0.0) v_aS(i,j) = Ds + max(Fs,0.0) v_aP(i,j) = v_aW(i,j) + v_aN(i,j) + v_aS(i,j) - Fw + Fn - Fs + 2*De v_b(i,j) = (2*De - Fe)*V_E + (p(i,j-1) - p(i,j))*del_x else v_aE(i,j) = De + max(-Fe,0.0) v_aW(i,j) = Dw + max(Fw,0.0) v_aN(i,j) = Dn + max(-Fn,0.0) v_aS(i,j) = Ds + max(Fs,0.0) v_aP(i,j) = v_aE(i,j) + v_aW(i,j) + v_aN(i,j) + v_aS(i,j) + Fe - Fw + Fn - Fs v_b(i,j) = (p(i,j-1) - p(i,j))*del_x end if end do end do !solving the u* momentum equation it = 0 do it = it + 1 do j = 1, jmax do i = 2, imax u_temp(i,j) = u(i,j) end do end do do j = 1, jmax do i = 2, imax u(i,j) = (u_aE(i,j)*u(i+1,j) + u_aW(i,j)*u(i-1,j) + u_aN(i,j)*u(i,j+1) + u_aS(i,j)*u(i,j-1) + & & u_b(i,j) + (1 - alpha_u)*u_aP(i,j)*u_temp(i,j)/alpha_u)*alpha_u/u_aP(i,j) end do end do temp = 0 do j = 1, jmax do i = 2, imax temp = temp + abs(u(i,j) - u_temp(i,j)) end do end do r = temp/((imax-1)*jmax) write(*,70),iter,it,r,u((imax/2),(jmax/2)) if(r < 1e-8) exit end do !solving the v* momentum equation it = 0 do it = it + 1 do j = 2, jmax do i = i, imax v_temp(i,j) = v(i,j) end do end do do j = 2, jmax do i = 1, imax v(i,j) = (v_aE(i,j)*v(i+1,j) + v_aW(i,j)*v(i-1,j) + v_aN(i,j)*v(i,j+1) + v_aS(i,j)*v(i,j-1) + & & v_b(i,j) + (1 - alpha_v)*v_aP(i,j)*v_temp(i,j)/alpha_v)*alpha_v/v_aP(i,j) end do end do temp = 0 do j = 2, jmax do i = 1, imax temp = temp + abs(v(i,j) - v_temp(i,j)) end do end do r = temp/((imax)*(jmax-1)) write(*,75),iter,it,r,u((imax/2),(jmax/2)) if(r < 1e-10) exit end do !calculating u residual temp = 0 do j = 1, jmax do i = 2, imax temp = temp + abs(u_aP(i,j)*u(i,j) - (u_aE(i,j)*u(i+1,j) + u_aW(i,j)*u(i-1,j) + & & u_aN(i,j)*u(i,j+1) + u_aS(i,j)*u(i,j-1) + u_b(i,j))) end do end do u_residual = temp/((imax-1)*jmax) !calculating v residual temp = 0 do j = 2, jmax do i = 1, imax temp = temp + abs(v_aP(i,j)*v(i,j) - (v_aE(i,j)*v(i+1,j) + v_aW(i,j)*v(i-1,j) + & & v_aN(i,j)*v(i,j+1) + v_aS(i,j)*v(i,j-1) + v_b(i,j))) end do end do v_residual = temp/(imax*(jmax-1)) !coefficients for pressure correction equation do j = 1, jmax do i = 1, imax !de = d_u(i+1,j) !dw = d_u(i,j) !dn = d_v(i,j+1) !ds = d_v(i,j) if(i == imax) then d_u(i+1,j) = 0 else d_u(i+1,j) = del_y/u_aP(i+1,j) end if if (i == 1) then d_u(i,j) = 0 else d_u(i,j) = del_y/u_aP(i,j) end if if(j == jmax) then d_v(i,j+1) = 0 else d_v(i,j+1) = del_x/v_aP(i,j+1) end if if(j == 1) then d_v(i,j) = 0 else d_v(i,j) = del_x/v_aP(i,j) end if aE(i,j) = d_u(i+1,j)*del_y aW(i,j) = d_u(i,j)*del_y aN(i,j) = d_v(i,j+1)*del_x aS(i,j) = d_v(i,j)*del_x aP(i,j) = aE(i,j) + aW(i,j) + aN(i,j) + aS(i,j) b(i,j) = -u(i+1,j)*del_y + u(i,j)*del_y - v(i,j+1)*del_x + v(i,j)*del_x end do end do !storing aP, aE, aW, aN, aS for a u cell in the center if(mod(iter,10) == 1)write(5,50) write(5,60),iter,u_aP(imax/2,jmax/2), u_aE(imax/2,jmax/2), u_aW(imax/2,jmax/2), & & u_aN(imax/2,jmax/2), u_aS(imax/2,jmax/2) !calculating continuity residual temp = 0 do j = 1, jmax do i = 1, imax temp = temp + abs(b(i,j)) end do end do c_residual = temp/(imax*jmax) if(mod(iter,10) == 1) write(*,30) write(*,40),iter, c_residual, u_residual, v_residual if((u_residual + v_residual + c_residual) < tolerance) then write(*,*),'the solution is converged' exit end if !solving pressure correction equation it = 0 do it = it + 1 do j = 1, jmax do i = 1, imax p_temp(i,j) = pprime(i,j) end do end do do j = 1, jmax do i = 1, imax if(i == 1 .AND. j == 1) cycle pprime(i,j) = (aE(i,j)*pprime(i+1,j) + aW(i,j)*pprime(i-1,j) + aN(i,j)*pprime(i,j+1) + & & aS(i,j)*pprime(i,j-1) + b(i,j))/aP(i,j) end do end do temp = 0 do j = 1, jmax do i = 1, imax temp = temp + abs(pprime(i,j) - p_temp(i,j)) end do end do r = temp/(imax*jmax) write(*,80),iter,it,r,u((imax/2),(jmax/2)) if(r < 1e-5) exit end do !correcting pressure do j = 1, jmax do i = 1, imax p(i,j) = p(i,j) + alpha_p*pprime(i,j) end do end do !correcting u velocities do j = 1, jmax do i = 2, imax u(i,j) = u(i,j) + d_u(i,j)*(pprime(i-1,j) - pprime(i,j)) end do end do !correcting v velocities do j = 2, jmax do i = 1, imax v(i,j) = v(i,j) + d_v(i,j)*(pprime(i,j-1) - pprime(i,j)) end do end do if(mod(iter,100) == 1)write(4,20),iter,u(imax/2,jmax/2) b = 0 temp = 0 do j = 1, jmax do i = 1, imax b(i,j) = -u(i+1,j) + u(i,j) - v(i,j+1) + v(i,j) temp = temp + b(i,j) end do end do temp = temp/(imax*jmax) write(*,*)'Mass imbalance after velocity correction is',temp end do close(4) close(5) !calculating stream function from velocity field do j = 1,jmax do i = 1, imax psi(i,j) = (u(i,j) + u(i+1,j))*del_x/2 + (v(i,j) + v(i,j+1))*del_y/2 end do end do write(*,*),'the u velocities at cell centers after',iter,'iterations are:' open(1, FILE = 'u.vel.txt') do j = 1, jmax write(*,'(1000f10.6)'),(u(i,j), i = 1, imax+1) write(1,'(1000f10.6)'),(u(i,j), i = 1, imax+1) end do close(1) write(*,*),'the v velocities at cell centers after',iter,'iterations are:' open(2, FILE = 'v.vel.txt') do j = 1, jmax+1 write(*,'(1000f10.6)'),(v(i,j), i = 1, imax) write(1,'(1000f10.6)'),(v(i,j), i = 1, imax) end do close(2) write(*,*),'the stream function at cell centers after',iter,'iterations are:' open(3, FILE = 'stream.txt') do j = 1, jmax write(*,'(1000f10.6)'),(psi(i,j), i = 1, imax) write(1,'(1000f10.6)'),(psi(i,j), i = 1, imax) end do close(3) deallocate(u, u_temp, u_aP, u_aE, u_aW, u_aN, u_aS, u_b, d_u) deallocate(v, v_temp, v_aP, v_aE, v_aW, v_aN, v_aS, v_b, d_v) deallocate(p, pprime, aP, aE, aW, aN, aS, b, psi, p_temp) end program |
November 18, 2017, 04:45 |
#11 | |
Rep Power: 71 |
Open a new post and describe better your convergence problem |
November 18, 2017, 08:40 |
#12 |
Karthikeyan
Rep Power: 9 |
Hi FMDenaro,
I have posted my question in a new thread. SIMPLE algorithm for lid-driven cavity not converging Thanks |
November 18, 2017, 12:10 |
#13 |
It seems you are using the forward differencing scheme to compute the divergence of velocity field?
We should use the CD scheme to compute it. For the pressure equation, a simple "insulation" BC can be used. |
Display Modes | |
Lid driven Cavity | suman91 | SU2 | 3 | May 24, 2022 06:23 |
Pressure variation in 2D lid driven cavity | Agad15 | Main CFD Forum | 0 | October 9, 2014 05:41 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 16:00 |
Lid Driven Cavity velocity profiles | new_at_this | Main CFD Forum | 0 | December 22, 2011 17:04 |
[OpenFOAM] Paraview - Lid Driven Cavity | kieranhood | ParaView | 0 | February 13, 2010 17:28 |
