please help in simulating a wind turbine blade in 6 DOF ????.... |
December 11, 2009, 01:51 |
USMAN
Rep Power: 16 |
I have a problem about the rotating simulation of wind turbine. I usually use 6 DOF UDF to calculate forces on a free falling body and its trajectory is found.But here the problem is wind turbine blade has to move about a fix point,not freely and wind flow work is done on the blades to make the blades rotating. In the wind turbine case, I only have the data of wind flow at 6 m/s. How do I simulate the wind flow work is done on the blades and then blades rotating? Regards.... I will wait for the kind reply from any1... |
February 24, 2016, 07:12 |
Ganesh Narayana
Rep Power: 10 |
Am trying to simulate a flow driven hydraulic turbine (a cross-flow impulse turbine) which looks exactly like your case. All i have is the inlet velocity of incoming water stream & i have to calculate the rpm of the rotor as the output. If i use steady state simulation then i have to go for mrf or srf, but for which i don't have the angular velocity of the rotor, how do i proceed? If i go for flow driven simulation then it is transient, Which one would be much more feasible using CFX ? |
March 10, 2016, 02:53 |
Rep Power: 12 |
From what i know, the usual (or preliminary) way of doing this is to generate multiple Performance graphs (Power vs. angular velocity) at different velocities.. the point where d(Power)/d(Angular Velocity)=0 [maximum power] on each curve is your optimum Angular Velocity.. leading to optimum flow velocity selection..
Both steady state & transient could be done in CFX with all the methods you have mentioned, but rotation of blades due to incoming flow using any method is computationally expensive (at times overwhelming, depending on what your looking for..) |
Mesh a twisted wind turbine blade | Laurenjiongo | Main CFD Forum | 6 | January 29, 2018 06:13 |
wind turbine blade | Lim | FLUENT | 1 | December 3, 2013 21:28 |
Can I use Turbogrid to mesh a wind turbine blade? | Henry Liu | CFX | 10 | November 10, 2011 05:41 |
Wind Turbine Blade Geometry | SeanieB | Main CFD Forum | 0 | November 27, 2009 10:18 |
Wind tunnel of a turbine blade tests. | Jonas Pedro Caumo | CFX | 3 | April 28, 2007 02:35 |
