Initial conditions in physical space from energy spectrum |
February 19, 2016, 00:51 |
Aru
Rep Power: 14 |
For validation purpose, I want to simulate homogeneous isotropic turbulence using my code. Following literature, my initial conditions have a known one dimensional energy spectrum . I need to give initial conditions in physical space, with grid points. I have learnt that I have to proceed as follows.
However in step 3, how will I do the orthogonalization process with my FFT data? What is the wavenumber vector , when FFT data has wavenumbers in the range in all 3 directions? |
February 19, 2016, 04:06 |
Filippo Maria Denaro
Rep Power: 71 |
February 19, 2016, 05:58 |
Thank you
Aru
Rep Power: 14 |
Thank you for the response.
However, the document does not have any additional information than what I understand now. My problem is specific. I have the amplitude-wavenumber information (data) after transformation to Fourier space. With my limited knowledge, I don't know how to get from this available data. |
February 19, 2016, 15:32 |
Rep Power: 71 |
using search function, you can find many posts in this forum about the initial conditions, for example:
http://www.cfd-online.com/Forums/mai...procedure.html |
energy spectrum, fourier transform, matlab |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Why RNGkepsilon model gives floating error | shipman | OpenFOAM Running, Solving & CFD | 3 | September 7, 2013 08:00 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
