Boundary Conditions for Natural Convection in Open Environment |
February 26, 2016, 22:17 |
Anonymous
I am working on ANSYS Icepak (which uses fluent solver) for a natural convection problem. There is a heated plate mounted on a vertical wall. Rest 5 sides, I am applying open boundary conditions at a significant distance (at least 10X of plate dimensions in each direction) from the heated plate. I am applying atmospheric pressure on these openings and no slip on the plate. My solution is converging but no matter what I do, I am getting flow vectors in the direction of gravity . I have tried various combinations of under relaxation values, boussinesq approximation, ideal gas approach, very fine mesh, increased iterations, transient solution and many other options. I guess, there is some issue in figuring out boundary conditions on the open sides. @Experts, please suggest something. Thanks, Munish |
fluent, icepak, natural convection |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Appropriate Boundary conditions for jet flow in open domain | shrutidhara.123 | FLUENT | 0 | August 5, 2014 10:27 |
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 07:32 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
