November 24, 2011, 14:09 |
lax friedrich scheme for shock tube problem.
Manu Kamin
Rep Power: 14 |
Hi
I have written a matlab code for shocktube problem using the lax friedrich scheme. However there seems to be a bug in it, due to which it is not giving me the expected results for plots of density, pressure and velocity. Can someone please help me debug it? Here's the code: clear all; close all; clc; R=287; %Cv=717; gamma=1.4; rhol=1; Ul=0; Pl=100000; rhor=0.125; Ur=0; Pr=10000; c=50; delx=20/c; delt=.0004278; lambda=.001069; for i=1:1:c+1 x(i)=-10+(i-1)*delx; end for i=1:1:c+1 if (x(i)<0) rho(1,i)=rhol; u(1,i)=Ul; p(1,i)=Pl; else rho(1,i)=rhor; u(1,i)=Ur; p(1,i)=Pr; end end for i=1:1:c+1 mom(1,i)=rho(1,i)*u(1,i); %t(1,i)=p(1,i)/(rho(1,i)*R); e(1,i)=p(1,i)/((gamma-1)*rho(1,i)); energ(1,i)=(e(1,i)+.5*u(1,i)^2); energrho(1,i)=energ(1,i)*rho(1,i); end for n=2:1:30 for i=2:1:c rho(n,i)= .5*(rho(n-1,i-1)+ rho(n-1,i+1))-.5*lambda*(u(n-1,i+1)*rho(n-1,i+1)-u(n-1,i-1)*rho(n-1,i-1)); mom(n,i)= .5*(mom(n-1,i-1)+ mom(n-1,i+1))-.5*lambda*(u(n-1,i+1)*mom(n-1,i+1)+p(n-1,i+1)-p(n-1,i-1)-u(n-1,i-1)*mom(n-1,i-1)); energrho(n,i)= .5*(energrho(n-1,i-1)+energrho(n-1,i+1))-.5*lambda*((u(n-1,i+1)*energrho(n-1,i+1)+p(n-1,i+1)*u(n-1,i+1) - u(n-1,i-1)*energrho(n-1,i-1)+p(n-1,i-1)*u(n-1,i-1))); energ(n,i)=energrho(n,i)/rho(n,i); u(n,i)=mom(n,i)/rho(n,i); e(n,i)=energ(n,i)-.5*u(n,i)^2; %t(n,i)=e(n,i)/Cv; p(n,i)=(gamma-1)*rho(n,i)*e(n,i); end rho(n,1)=rho(1,1); rho(n,c+1)=rho(1,c+1); mom(n,1)=mom(1,1); mom(n,c+1)=mom(1,c+1); e(n,1)=e(1,1); e(n,c+1)=e(1,c+1); %t(n,1)=t(n,2); %t(n,1)=e(n,1)/Cv; %t(n,c+1)=t(n,c); %t(n,c+1)=e(n,c+1)/Cv; p(n,1)=p(1,1); %p(n,1)=rho(n,1)*R*t(n,1); p(n,c+1)=p(1,c+1); %p(n,c+1)=rho(n,c+1)*R*t(n,c+1); u(n,1)=u(1,1); %u(n,1)=mom(n,1)/rho(n,1); u(n,c+1)=u(1,c+1); %u(n,c+1)=mom(n,c+1)/rho(n,c+1); end %t=plot(x,p(30,: ),'or'); %axis([-10 10 0 100000]) %t=plot(x,u(30,: ),'or'); %axis([-10 10 -150 450]) t=plot(x,rho(25,: ),'or'); axis([-10 10 0 1.1]) Thanks Manu |
November 25, 2011, 00:15 |
Manu Kamin
Rep Power: 14 |
Hi
never mind.. I fixed it.. I was not updating the value of energy at boundary points and it was hence taking default value of zero which is not correct. |
November 3, 2013, 02:21 |
Alpesh
can you tell me what is lambda here? also can you post the updated code? |
March 22, 2016, 01:02 |
Yi Han
Rep Power: 12 |
Hi, can you upload the updated code?
Thanks so much! |
Problem simulating wave propagation in a tube | cKnoop | OpenFOAM Running, Solving & CFD | 6 | August 22, 2011 15:28 |
Problem with using icoFoam for flow in a straight tube | edificelp | OpenFOAM | 4 | February 11, 2011 03:27 |
problem about numerical scheme in LES. | libin | Main CFD Forum | 4 | July 1, 2004 04:32 |
Shock tube problem | ger | Main CFD Forum | 1 | September 24, 2003 07:41 |
Difference between Lax and MacCormack methods on solutions of 1D problem. | AERO | Main CFD Forum | 2 | January 19, 2000 14:36 |
