March 27, 2016, 21:51 |
Propeller shrouds & Ground effect
srinath
Rep Power: 10 |
Hi
It is a view held by many that Propeller shrouds increase static thrust. Is this true? If so why and what design criteria should the shroud meet ? We all know that when a propeller is brought close to the ground, it experiences an increase in lift. If we placed a plate directly under the propeller, would the plate+propeller combination experience a net change in thrust? What if the plate were spinning (and pushing the air outwards--think flow past a spinning disk, that should reduce the pressure build up over the plate) |
ground effect, propeller, shroud |
full simulation of an aircraft with propeller effect | kdrbrk | FLUENT | 3 | January 17, 2024 03:08 |
Flow Analysis Around Aircraft with Propeller Effect | theengineer | Mesh Generation & Pre-Processing | 0 | August 13, 2013 05:37 |
Ground effect on 2d airfoil | stacey | FLUENT | 0 | July 29, 2013 04:18 |
wing in ground effect | meenakshi | FLUENT | 1 | July 12, 2008 13:29 |
ground effect fluent modelling | meenakshi | FLUENT | 0 | June 11, 2008 01:09 |
