Viscosity limit between turbulence models
Old   April 6, 2016, 00:31
Default Viscosity limit between turbulence models
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hello every,
I am curious to know that is there any viscosity limit bellow which we can use boussinesq hypothesis turbulence models (SA, ke, kW) and above which we have to use RSM turbulent models. Is there any dimensional number to identify these difference for quickly selecting turbulent model.
Thank you
Regards,
Sunil
sunilpatil is offline   Reply With Quote
Old   April 6, 2016, 04:17
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by sunilpatil View Post
Hello every,
Thank you
a physical reasoning guides to consider the minimum value to zero as negative values would imply an anti-diffusion effect that is somehow related to a backscatter of energy
FMDenaro is offline   Reply With Quote
Old   April 6, 2016, 05:17
sunilpatil's Avatar
sunil
Hi denaro,
Can you please explain it. I am not understanding anti- diffusion effect and back scatter of energy.
Regards,
Sunil
Old   April 6, 2016, 05:20
Hi denaro,
immagine the diffusive flux of momentum, for positive values of the viscosity, it acts to smooth gradients. Conversely, an anti-diffusion due to negative values of the viscosity will tend to further increase a gradient.
Old   April 6, 2016, 11:28
sunilpatil's Avatar
sunil
Hi denaro,
Thanks for your reply.
Regards,
Sunil
Turbulence and viscosity of non-Newtonian Fluids David FLUENT 9 October 30, 2023 05:55
Eddy Viscosity Models and Reynolds Stress Models JuPa CFX 1 August 20, 2013 19:56
turbulence models? haider FLUENT 0 March 8, 2006 00:58
Turbulence Models and external flow. Alan FLUENT 3 November 22, 2005 05:46
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 16:39
