[Sponsors] | |||||
Hashir Shafi
Rep Power: 0 ![]() |
I am having an invalid command error when I am entering the following command in my fluent window.
(rpsetvar `temperature/shell-secondary-gradient? #f) Attached is the screenshot showing command and resulting error.Please guide me if I am writing this command at the wrong place. I was asked to type this command in the TUI. I will be grateful if anybody solved the problem. |
Rep Power: 11 ![]() |
i had a similar problem, i tried to write (rpsetvar 'temperature/secondary-gradient? #f) which wasn't allowed. I had to first write /solve/set/expert Answer the question 'use alternate formulation for wall temperatures?' with 'yes'. All other can be default then write (rpsetvar 'temperature/secondary-gradient? #f) maybe this is it? Maybe you need to answer the questions differently? hope it helps |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| parallel simulations - error message: "OPT_ITERATIONS: invalid option name" | v8areu | SU2 | 5 | July 23, 2015 03:57 |
| [swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
| Problems building Paraview 3.12 on Gentoo Linux | pajot | OpenFOAM Installation | 11 | April 11, 2013 09:09 |
| OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 06:48 |
| Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
