laminar flow in circular pipe
Old   January 1, 2009, 11:57
Default laminar flow in circular pipe
MLA
Hey! I'm looking for a test case to verify my code. I used FVM(fortran code) to simulate a laminar flow in pipe can any one help or send me a paper? Thanks in advance
Old   January 1, 2009, 18:25
Default Re: laminar flow in circular pipe
otd
Hagen-Poiseuille flow through a pipe for flow downstream of the inlet section. The flow is independent of z there (at least until turbulence sets in). The axial velocity is parabolic, w(r, z), where r is the radial coordinate. Use mass converation to learn that the CL axial velocity is 1.5 x the average axial velocity. My old version of Schlichting (Boundary Layer Theory) has it all worked out.
For the entrance region flow, find some data (friction factors?). Compare the CL axial velocity w(r = 0, z) from your calculation with the data.
Old   January 3, 2009, 11:41
MLA
dear otd thanks for your message.but there is a little problem in parabolic velocity i.e. the coeficient is depend on pressure drop which is unknown befor solving the problem! as you know the inlet and outlet bc's are velocity inlet and prresure outlet .thanks again
Old   January 3, 2009, 22:06
versi
The pressure drop may be given a-priori.
Inlet BC: Pressure = given, u-component = extrapolated according to du/dx=0, v-component =0,
Outlet BC: pressure =0.0, d(u,v)/dx=0
Old   June 27, 2012, 09:53
Goutam Saha
Goutam is on a distinguished road
Originally Posted by MLA
;58387
Hi, Did you find a paper? Could you please email me the paper, I am using FVM (fortran code) to simulate a laminar flow in pipe. Could you please answer my following questions:
Also, how I will calculate the inlet and outlet pressure? I have used parabolic velocity profile and my velocity and pressure graph looks correct.
Also, how I will calculate the Nusselt number? (Looking for a fortran code)
Thanks for your time.
Goutam
Goutam is offline   Reply With Quote
Old   July 1, 2012, 17:55
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
Goutam
Hi. You don't need a paper. Just check any basic fluid mechanics textbook and you will find a formula for dp/dx (or derive it quite easily). Since dp/dx is constant, the pressure profile is a line. Assuming you specified an outlet pressure you can find the correct pressure anywhere else.
cdegroot is offline   Reply With Quote
Old   July 2, 2012, 07:11
Goutam Saha
Hi
For my case, I use water as fluid for laminar pipe flow problem. I found that flow is fully developed from inlet to outlet since I used parabolic velocity profile at the inlet. Also pressure is decreasing from inlet to outlet. Problem is my pressure drop profile is not linear and I calculated the friction factor which is not good at all. (Analytical result: f = 64/Re). But my velocity profile is fully correct. But when I use air as a fluid, then all my results were correct.
Thanks
Old   July 3, 2012, 13:06
Goutam Saha
My problem is solved and I am now getting the correct pressure drop results. Only problem remains is the Nusselt number !!!!!!!!!
Old   April 13, 2016, 11:19
Default flow through a channel
avr
crazyrudra1 is on a distinguished road
hey goutam
i am doing exactly the same thing. any chance i could hav a look at your fortran code?
thx
crazyrudra1 is offline   Reply With Quote
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Flow laminar and stationary of water in a pipe manuel OpenFOAM Running, Solving & CFD 6 March 24, 2007 18:23
First steps - laminar flow in a pipe Maria Phoenics 8 November 27, 2001 11:26
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
