April 27, 2016, 17:37 |
Density base/pressure base
zxc
Rep Power: 11 |
Hi i want to model a pipe that air flows in and other pipe inside this pipe that contain water flow.The mach number of air is 4,and
my problem is that i want to simulate in fluent and what should i choose density based or pressure based method to solve this problem? what are the other ways to simulate this physic? Thanks |
April 27, 2016, 19:41 |
Michael Prinkey
Rep Power: 25 |
If this is a two-phase flow, I think you are going to have to use the pressure-based solver. If memory serves, none of the Fluent does not support any multiphase capabilities in the density-based solver.
But honestly, you are looking at Mach 4 air flow in a pipe mixed with liquid water? |
April 28, 2016, 05:37 |
zxc
Rep Power: 11 |
No water flows in pipe 1 and air is in pipe 2 ,but the pipe 2 is inside pipe 1(concentric) .It means segregate flows.
we have need to calculate heat transfer. |
April 28, 2016, 09:16 |
Michael Prinkey
Rep Power: 25 |
OK, that makes more sense. Generally, the density based solver works better for highly compressible flows. I think there is enough preconditioning done in the density-based solver to let it work reasonably well at slow speeds for the water side. I'd probably start there.
Good luck. |
April 28, 2016, 21:26 |
#5 | |
Arjun
Rep Power: 34 |
Edited to remove the answer as it will not work. You would have to create very thin solid layer in between. |
April 28, 2016, 21:35 |
Arjun
Rep Power: 34 |
BTW in my solver I think you can do it. I will try when I get time.
Density base/pressure base | zxcvasdf | FLUENT | 2 | April 28, 2016 05:45 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
