May 8, 2016, 13:32 |
Y+ estimation for pipe flow
YuJi
Rep Power: 10 |
For a turbulent flow in tube with circular section, how can i estimate the value of Y+ to ensure the mesh and adoption of wall functions. Especially, how to determine the friction velocity, or the wall shear stress?
p.s. The estimation of Y+ for boundary layer is clear now, but i don't know whether it is ok to use the same approach or relation in internal flow. |
May 10, 2016, 07:51 |
Onur Özcan
Rep Power: 12 |
y+ is dimensionless, it changes flow Reynolds number according to flow medium type (like internal flow in pipes and external flows around cylinder)
First you should define local reynolds number and then that boundary layer is into laminar or turbulent flow boundary layer. then you should specify it if your model is in laminar boundary layer y+=1 or max 5 or otherwise you might as well define it as y+=30 ( if you are working on compressible flow, y+>30 or 60 for sure.) then some formulation is available in websites by calculating y+ (you have defined) you will find out y (first layer thickness) then give it in your mesh model , |
May 10, 2016, 10:43 |
#3 | |
YuJi
Rep Power: 10 |
May 10, 2016, 12:08 |
Onur Özcan
Rep Power: 12 |
cf is piece of cake (http://www.cfd-online.com/Wiki/Skin_...n_coefficient) you could use formula in top page of website)
https://en.wikipedia.org/wiki/Law_of_the_wall, you need to calculate manually y ( first layer thickness).That link help you out with.( you can choose any cf in first link) You could combine all formulas ( second link and first link-top pag of website) that is, mean velocity is u , u(subscript t) = friction velocity both terms are used in your calculation. Kind Regards, |
friction velocity, pipe flow, wall shear stress, y plus |
Different flow patterns in CFX and Fluent | avi@lpsc | CFX | 6 | April 17, 2012 01:22 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Estimation of the flow coefficient of an intake valve | lucchini | OpenFOAM Running, Solving & CFD | 3 | February 7, 2006 10:11 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
