Negative Aorta Flow Convergence Issue
Hello all,
First of all thank you for the support provide to the CFD community with this forum. I am using a transient model to analyze the aorta blood flow. My boundary conditions are a mass flow waiveform at the aorta inlet and the Windkessel model at the outlet. I am using Piso solver. My problem is that the aorta waiverform has a negative peak (reflux through the aorta valve), once the simulation reaches this negative value the solution diverges. I have tried to reduce the time step, to use an adapative time step, to refine the mesh, but nothing worked. Did anybody experience the same problem? Thank you in adavance. |
when you have reflux, I suppose two things can happen: 1) the walls are elastic and the volume diminuishes or 2) the walls are rigid and you have reverse flow from the outlet. I think you have to describe better your model and check if the BC.s are able to satisfy the continuity equation for all the conditions. |
is that a laminar flow
Are you using a laminar flow model?... I think it would be an improvement to use transitional model in all this applications like the k-kl-omega model or the mos recent one k-omega-v2 model ("Prediction of transitional and fully turbulent flow using an alternative to the laminar kinetic energy approach")
