June 27, 2016, 06:48 |
XFlow Naca 0012 Validation
Berkay Yasin YILDIRIM
Hello. I am trying to validate XFlow results. I have started with analyzing NACA 0012 for Re 3000000. I have generated 3D NACA 0012 with 10k points,and analyzed in 2D. I could not get close results to the experimental airfoil data. I used 0.2 resolved scale, around 0.0003m target resolved scale and 0.004m wake resolution. It took 1.5 hours but not a valid result. How can I increase accuracy or what can be wrong about my approach? Thank you
June 27, 2016, 13:05 |
Matt
Rep Power: 17 |
you have 10k nodes or cells? either way, your mesh sounds much too coarse for this analysis.
what do your wall y+ values look like and what turbulence & wall models are you using? |
Data for NACA 0012 | Muntazir | Main CFD Forum | 1 | March 28, 2023 01:59 |
How to import NACA 0012 Profile in Gridgen | maplepink | Main CFD Forum | 17 | May 7, 2013 13:01 |
NACA 0012 Case Will Not Converge | dancfd | OpenFOAM Running, Solving & CFD | 6 | November 14, 2011 19:09 |
Problems with flat plate and NACA 0012 Lift/Force | Harly | FLUENT | 0 | June 18, 2007 10:02 |
NACA 0012 simulation results | Luis | FLUENT | 3 | February 15, 2006 11:42 |
