July 13, 2016, 15:11 |
y+ influence
Marco Palermo
Rep Power: 10 |
Dear all,
I am simulating the flow past an airfoil in transonic conditions. I am using the SST turbulence model, as first part of my task there is simulating the flow using a y+ value between 10 and 500. I have found that increasing the y+ value the result matches better and better with the experimental data I have. As you can see in the below figures. [IMG][/IMG] [IMG][/IMG] As you can see, as y+ decreases the result becomes worse. What I expected was better results for smaller y+ values. The second part of my task is to " to refine the mesh around the shock location and by achieving y+ ≈ 1 at the airfoil boundary". Does anyone know how to do that? Because, using the y+ calculator with y+ distance equal to 1 , after the simulation I have found y+ = 1 at the trailing edge of the airfoil while inside it went smaller than 1. My mesh is a C-grid. The software I am using is CFX. Thank you very much for your help |
July 14, 2016, 08:58 |
robo
Rep Power: 12 |
CFX should be able to output local y+, so that you don't need to try and back calculate it afterwards. That'll probably get you a better result.
In the Cp vs position graph: for the majority of the airfloil, it looks to me like all y+ values are close enough; likely within the experimental accuracy, which ought to be reported for a study like this. The major difference is around the shock, which could be attributed to mesh spacing; ie for the same mesh size in number of cells, you might be getting better longitudinal spacing by relaxing the y+ requirement. I'd need to know more about how you meshed to really say much about that though. Also, Cp is going to have a largely inviscid character in unseperated flow, so I wouldn't expect much y+ dependence anyway. I imagine that if you looked at viscous drag, there would be significantly more y+ dependent. I'm unclear on what the theta vs speed graph is showing me, and I'm suspicious that its mislabeled, since the the graph shape is exactly the same as the other, and the speed value goes from 0 to 1. |
July 14, 2016, 10:05 |
Alex
Rep Power: 46 |
Have you made sure that y+ is the only source of error in your simulations or at least significantly larger than the other error sources?
July 14, 2016, 11:10 |
#4 | ||
Marco Palermo
Rep Power: 10 |
Anyway I have done some modifications to the mesh grid changing the spacing downstream the airfoil from equispaced to exponential as you can see below. [IMG][/IMG] And I also did a small error in the Reynolds, the new plots are for y+ equal to 1 and 250. [IMG][/IMG] The same trends seem to appear, the max expansion is reduced and the shock location is more upwind. Do you have any suggestion about the spacing on the airfoil? I am using ICEM. Quote:
Thank you |
Influence of schemes on mesh size, orientation and type in a convective flow field | Tobi | OpenFOAM Verification & Validation | 8 | July 16, 2017 08:01 |
[ANSYS Meshing] Creating local sizings within a body of influence. | Euan001 | ANSYS Meshing & Geometry | 1 | May 6, 2016 04:19 |
[ANSYS Meshing] Body of Influence | MuhammadK | ANSYS Meshing & Geometry | 3 | January 8, 2016 01:27 |
Body of influence issues | st268 | CFX | 6 | September 4, 2012 02:12 |
[ANSYS Meshing] Bodies of Influence Settings / Problem | cycleodyssey | ANSYS Meshing & Geometry | 1 | January 11, 2012 16:57 |
