July 5, 2016, 03:38 |
Airfoil Polar?
CFD
Rep Power: 16 |
Hey All,
I was wondering if there is any software that could provide the lift and drag for angle of attacks from -180 to 180? As can be seen from the wind tunnel experiments, the data available is only from -20 to 20. Any help would be really appreciate it. Kind regard, |
July 5, 2016, 09:30 |
Matt
Rep Power: 17 |
NREL provides a free spreadsheet program called Airfoil Prep that applies the Viterna method for calculating post-stall characteristics of airfoils through 360 degrees.
https://nwtc.nrel.gov/AirFoilPrep http://www.nrel.gov/docs/fy05osti/36900.pdf |
July 7, 2016, 01:24 |
CFD
Rep Power: 16 |
Thank for your kind help.
Regards, |
July 13, 2016, 14:42 |
Gonzalo
Rep Power: 16 |
Hi:
If you are working on wind turbine airfoils NREL has some reports having CL, CD and CM data in such a range of AoA. If you aren't working on wind turbine airfoils, NTRS (NASA Technical Report Server) has some reports with that data. For hi Reynolds and Mach numbers you have the report DATCOM with tendencies on the behavior of that curves at high AoA for some thin profiles. In the case you are working on a new profile, mmm, well you have to construct your own data with CFD or your own wind tunnel Regards. Gonzalo |
July 13, 2016, 15:59 |
CFD
Rep Power: 16 |
Thank you for your kind reply. I am currently working on wind turbines and trying to use airfoil polar in order to transform some airfoils from AoA -20 to 20 to -180 to 180. I have observed that what ever airfoil I transform from -180 to 180 the drag and lift are zero. Not really sure whether this is correct or not. Have you had the same experience?
Kind regards, |
July 14, 2016, 18:20 |
Gonzalo
Rep Power: 16 |
You are welcome. If with "transform" you mean rotate the airfoil around its pitch reference point, well it is expected that the lift force becomes zero or near zero starting from a high AoA, because the airfoil is at a flow condition named stall where the lift drops drastically but the drag rises drastically too. So, it is strange that in your case the drag drops to zero too. I will double check your result if I were you. Regards
Gonzalo |
Display Modes | |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
High drag for airfoil compared to XFOIL and wind tunnel data | Ry10 | SU2 | 15 | October 30, 2016 17:27 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
