Stream Function Formulation
Old   February 8, 2000, 13:35
Default Stream Function Formulation
Hong
Hi, dear Is it possible to use stream functions to calculate 2-D transonic flows? Is the compressible solution (Mach number) unique for a given stream function? Any references would be greatly appreciate.
Old   February 8, 2000, 17:18
Default Re: Stream Function Formulation
John C. Chien
(1). A. H. Shapiro, "The dynamics and thermodynamics of compressible fluid flow", vol.2, 1954, the Ronald Press, Chapter-21, transonic flow, section 21.5 relaxation method, p-836. (2). The stream function can be defined from steady,compressible,2-D continuity equation.
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
