August 4, 2016, 06:57 |
difference between jet and spray
James
Rep Power: 12 |
Dear all,
I would like to make a comparison for cooling techniques of heated surfaces using DPM. I am planning to inject particles from a surfaces and particles will travel through a hole and then expand in a chamber until they arrive to the heated surface. How can I make the difference between jet and spray cooling techniques? I mean, if nozzle diameter is fixed, the difference between jet and spray will be the particle diameter? (let's say particle 1e.-04 m means jet and 1e-09 m means spray?) Or is it something more related to the diameter of the nozzle? (let's say nozzle diameter of 5 mm means jet flow and nozzle diameter of 0.001 mm means spray flow) I cannot understand how clearly establish this difference. Thanks in advance |
trying to model a water jet spray on to a rotating mesh | arunprabhakar94 | Main CFD Forum | 0 | March 28, 2015 12:30 |
spray atomization simulation and analysis | Tribikram | FLUENT | 0 | September 14, 2012 13:36 |
jet two phase spray and evaporation | Tag | OpenFOAM | 1 | March 18, 2011 11:51 |
Help!simulation of free water jet | Annie | FLUENT | 3 | June 29, 2009 00:51 |
water jet spray | structure | FLUENT | 0 | June 23, 2009 01:48 |
