The size of the computational domain
Old   March 19, 2004, 10:42
Default The size of the computational domain
CFD Rookie
Hello everyone,
I have a quick question here. I am trying to model a full size airplane (half an airplane: cut along the X-Z plane). What is the probable size of my overall computational domain. Should I use the airplane overall fuselage length as my reference or the wing geometric chord (c_bar) as my reference length or something else? In terms of upstream, downstream, lateral side, upper and lower boundary, how far is far enough?
Thanks in advance.
Old   March 19, 2004, 11:36
Default Re: The size of the computational domain
Jarmo Monttinen
What is your Reynolds number etc? I don't have the fuselage in my computations so I've use the wing max chord and the wing span. Upstream, upper and lower about 5*chord, downstream about 10*chord, the side depends more on the Re, the wing span, etc... I have used about 3*span but have a LAR wing so for a higher AR wing that would be an overkill. I started with a slightly smaller domain and increased to these, further increase did not change the results.
I hope this helps.
-- Jarmo
Old   March 21, 2004, 09:23
versi
Supersonic -> upstream BC can be nearer. Subsonic -> upstream 1-2 full plane length Lateral: based on win-span. Anyway, there are lot Refs. for you.
Old   August 22, 2016, 04:12
Default Size of computational domain
Pradyuman
pradyuman is on a distinguished road
How to calculate the size of computational domain in case of flow past bluff bodies?
pradyuman is offline   Reply With Quote
Optimum Size of Rotating Domain in MRF vismech STAR-CCM+ 5 April 24, 2020 00:15
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
computational domain & boundary condition novice Main CFD Forum 0 May 8, 2006 19:30
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
