Static Pressure Inlet - Static Pressure Outlet |
August 26, 2016, 18:25 |
Rep Power: 10 |
My FDM code simulates Backward Facing Step flow when I use conventional BCs such as defining velocity profile at inlet and fully developed condition at outlet. I have validated the results and it seems functioning correctly. However, when I want to impose a pressure-pressure condition (both static), it only converges when a zero-gradient condition is selected for inlet. When I try to use mass balance to update inlet normal velocity at each iteration, the solution eventually blows up. I am integrating outflow and use the mean velocity as a uniform inlet velocity. Also I am interested to know if there is any difference to use momentum balance and mass balance to update inlet normal velocity. Has anyone faced this problem before? I appreciate your help |
August 26, 2016, 22:22 |
duri
Solution will not converge when Neumann boundary condition is used for a variable at all boundaries. Static pressure-static pressure boundary condition has no meaning, one of the boundary condition should contain velocity. When four equations are solved four variables should be specified as Dirichlet boundary condition.
August 27, 2016, 03:58 |
#3 | |
Filippo Maria Denaro
Rep Power: 71 |
Well, you should provide more details... 1) are you using Neumann at walls and Dirichlet at inflow and outflow? what about the pressure difference ? 2) are you using staggered or colocated grid? 3) how do you discretize the pressure equation? |
August 29, 2016, 23:40 |
Rep Power: 10 |
Thanks Duri and Filippo for your comments. I am using a collocated explicit MacCormack (predictor-corrector) scheme for incompressible flow with pseudo-compressibility coupling for pressure. The BCs that converge for pressure-pressure are listed below:
@inlet: p=p_in , du/dx=0 , dv/dx=0 @outlet: p=p_out , du/dx=0, dv/dx=0 @walls: dp/dy=0 (or the extended version) , u=0, v=0 The BCs that won't converge: @inlet: p=p_in , u=U_in , v=0 @outlet: p=p_out , du/dx=0, dv/dx=0 @walls: dp/dy=0 (or the extended version) , u=0, v=0 I find "U_in" from mass conservation at the end of each iteration and update it. I have used pressure-pressure condition in CFX without zero-gradient condition so many times, so there should be a way for convergence. |
August 30, 2016, 02:49 |
Rep Power: 71 |
The error is that you can not prescribe both pressure and velocity as Dirichlet bc
August 31, 2016, 19:33 |
Rep Power: 10 |
Thanks Filippo. I did not know about this. Could you kindly introduce me a book or paper that discusses what kind of Dirichlet and Neumann conditions go well together?
August 31, 2016, 22:59 |
#7 | |
duri
September 1, 2016, 03:35 |
#8 | |
Rep Power: 71 |
https://www.researchgate.net/publica..._viscous_flows |
September 2, 2016, 02:29 |
#9 | |
Rep Power: 10 |
September 2, 2016, 05:19 |
Rep Power: 71 |
compressible or incompressible???
pressure-pressure bc |
interFoam (HELYX-OS) pressure boundary conditions | SFr | OpenFOAM Running, Solving & CFD | 8 | June 23, 2016 16:36 |
Reversed flow using Pressure inlet and pressure outlet | didimad | FLUENT | 0 | March 14, 2015 05:38 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
simple model, difficult outlet | Eric | CFX | 7 | May 23, 2014 08:13 |
pump outlet pressure higher than inlet pressure | jstan3 | FLUENT | 14 | February 13, 2014 23:44 |
