February 23, 2000, 14:35 |
Validation-
Greetings, I'm trying to validate my CFD code for the problem I'm working on by using benchmark experimental data.
Would some one be able to tell me where can I find results for a simple straight pipe/Tube with heat transfer to start with. This would help me start validating the code before going into more complex geometries. Thanks |
February 24, 2000, 15:38 |
Re: Validation-
Simple tube problem is an easy one, generally you can obtain exact solution by solving the governing equations.. I dont know what kind of flow you have in this pipe..any how i can help you if u can specify more about the nature of the fluid you have in this pipe..hope you good luck
Validation test for 2d euler equations in subsonic regime with canonical squares | panou | Main CFD Forum | 2 | August 24, 2011 15:21 |
Validation of Star CCM+ | iand | Siemens | 2 | December 8, 2010 06:59 |
Validation cases | GGerber | OpenFOAM | 7 | October 30, 2010 04:11 |
Oscillating flow around cylinder validation error | Zak | FLUENT | 0 | September 22, 2005 16:09 |
Urgent: RAE 2822 validation | NID | Main CFD Forum | 0 | September 3, 2004 10:34 |
