Mesh from x,y location
Like Tree5Likes
  • 1 Post By mprinkey
  • 1 Post By FMDenaro
  • 1 Post By amirhosseintaran
  • 2 Post By mprinkey
Old   September 11, 2016, 15:53
Default Mesh from x,y location
mohammad fazli
mostanad is on a distinguished road
hi
I made a file that produce for me the location of corners of cells.I should connect them to produce for me the meshes(cells). but as i think there is no way to code it. I wanna show this grid in Tecplot.
mostanad is offline   Reply With Quote
Old   September 11, 2016, 16:11
Michael Prinkey
mprinkey will become famous soon enough
A list of node locations does not uniquely define a mesh either for cfd computation or for visualization. This is often called a "point cloud." There must be connectivity information included as well, either implicitly or explicitly. Implicit connectivity requires some detailed knowledge and constraints on your node ordering--say for a stretched cartesian mesh, you could deduce connectivity based on node ordering if you knew the number of nodes in the x and y directions. If your mesh is unstructured, you need to define connectivity, say by providing nodes that group together into cells.
You can refer to gmsh documentation for an example of how this is done:
http://gmsh.info/doc/texinfo/gmsh.ht...II-file-format
mostanad likes this.
mprinkey is offline   Reply With Quote
Old   September 11, 2016, 16:15
Filippo Maria Denaro
FMDenaro will become famous soon enoughFMDenaro will become famous soon enough
I agree, check chap.s 3 and 4 in
http://www.aertia.com/docs/tecplot/tpum.pdf
FMDenaro is online now   Reply With Quote
Amirhossein Taran
amirhosseintaran is on a distinguished road
I had the code on fortran !
If you want , i will send it to you
I think you are iranian from your name !
Contact me :
det.em.tw@gmail.com
Sent from my iPhone using Tapatalk
amirhosseintaran is offline   Reply With Quote
Old   September 11, 2016, 17:18
mohammad fazli
thanks
but what is the requirements? my written code is very long and i can put the requirement of tecplot on it. but really i don't know the true format in tecplot for generating .DAT file in fortran. your texts was so good but i want to know the requirements to put it in my code.
Old   September 11, 2016, 17:20
mohammad fazli
thanks Mr denaro.
but I don't know the phrases of my problem to search in this PDF. what is named my case exactly? and what is it's requirements in tecplot?
Old   September 11, 2016, 17:21
mohammad fazli
Contact me :
det.em.tw@gmail.com
I send you a mail. plz read it.
Old   September 12, 2016, 03:02
mohammad fazli
not more idea???!!!
Old   September 12, 2016, 06:46
Michael Prinkey
The file format is documented in Chapter 4. If you are doing single-block mapped 2D cartesian grid generation, which I infer from your other earlier question, you should be able to use the IJ-ordered data points format as documented in 3.3.1.2 of that .pdf. The ASCII output for iJ-ordered data is documented in 4.2.2. The information is all there. If you understand how your grid generation works, it should be easy to follow their recipe and turn it into a tecplot file.
FMDenaro and mostanad like this.
Old   September 12, 2016, 14:01
Default thanks to all
mohammad fazli
Mr mprinkey, FMDenaro and amirhosseintaran
thank to you. finally I learn how to write my Fortran code.
best regards to you.
Old   September 12, 2016, 16:09
Amirhossein Taran
hi
i didn't receive any mail !
i've been waiting for your respond !
anyway ,
please send it again or this is my number : +98 911 460 4459
best regards .
Old   September 12, 2016, 17:31
mohammad fazli
hi
anyway ,
best regards .
Don't be sensitive baradar.
Finally neveshtamesh. Tashakor
Old   September 13, 2016, 06:37
Amirhossein Taran
Glad to hear that buddy
Eyval (y)
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 24 June 27, 2016 08:54
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
No layers in a small gap bobburnquist OpenFOAM Native Meshers: snappyHexMesh and Others 6 August 26, 2015 09:38
SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Mesh Utilities 1 February 25, 2015 08:05
