September 16, 2016, 11:54 |
my fortran problem
mohammad
Rep Power: 11 |
Hi
I am using a DO loop, that it has many subroutines in it. but the subroutines seems doesn't work. if I get in subroutines in main code the code works!!! what is problem of subroutine with do loop? |
September 16, 2016, 12:05 |
Alex
Rep Power: 46 |
There is no inherent problem with subroutines in do-loops. The problem must be your specific implementation. Maybe if you give enough information someone can comment on that. Until then, you will have to do the usual debugging.
September 16, 2016, 12:16 |
Filippo Maria Denaro
Rep Power: 71 |
I agree, that for sure due to a programming error.
Check the variables type you pass in the call and use the debugging option. |
September 16, 2016, 16:06 |
#ind
mohammad
Rep Power: 11 |
Mr denaro, what does mean #ind in numbers for compiling fortran77?
September 16, 2016, 16:12 |
Rep Power: 71 |
September 16, 2016, 18:48 |
mohammad
Rep Power: 11 |
September 17, 2016, 03:29 |
Rep Power: 71 |
Use all the debug option in the compilation without optimization.
Check for array bound violation, type mismatch, etc. |
Problem with fortran file execution | FarzinD | CFX | 4 | March 27, 2017 11:05 |
problem about user fortran | xyq916 | CFX | 0 | January 27, 2015 07:38 |
Fortran compiler problem | Luke | Siemens | 2 | September 18, 2008 03:43 |
Problem with Fortran installation. | skarp | CFX | 0 | August 4, 2007 07:09 |
'C' or FORTRAN or 'C++' | Yogesh Talekar | Main CFD Forum | 20 | October 21, 1999 04:00 |
