Multi-element airfoil analysis
Old   February 8, 2004, 19:51
Default Multi-element airfoil analysis
CFD Rookie
Has anyone out there ever analyzed apllication such as high lift devices on the wing (to be more specific I want to carry out 2D multiple element airfoil types of analysis to estimate CL max & CD max)?
For the past few days, I was trying to model a NACA 2415 airfoil (clean airfoil w/o any slat or flap, RE = 6e6) at alpha = 0 deg and 2 deg and compare the Cl and Cd values with those in the Theory of Wing Sections. I have carried out the mesh dependency test on the same test case and at the end, the Cl predicted is only about 50% of the theoretical value, and Cd is 300% of those in the book. My mesh density on the airfoil surface is (0.5%*airfoil chord). Is this enough?
Can anyone give me some insight on how to tackle this type of problem? Greatly appreciated the help Thanks!!!!
Old   February 9, 2004, 03:01
Default Re: Multi-element airfoil analysis
Charles Crosby
If you're doing a single element airfoil, use XFoil (it's free) to at least get reference values, so that you know where you are slipping up. Averaged 0.5% of chord for cell-spacing is plenty fine enough, but you probably want to cluster it more to the leading edge. Drag will always be difficult to get right, because the RANS turbulence modeling approach will not automatically predict laminar - turbulent transition correctly. If you are using Fluent or CFD-Fastran I can give you example files that work OK.
Old   February 9, 2004, 10:18
CFD Rookie
Thanks for your insight. Currently I am running CFdesign (a finite element code).
By the way, when you say you have some "ok" example files, what do you mean by that? Have you ever obtained any sorts of results that are within 10% of theoretical values?
Old   February 10, 2004, 01:22
Charles Crosby
Getting lift within 10% is no problem. The drag can be whatever you want it to be ;-) , because it is dependent on selection of turbulence model, enforced (or not) transition, wall functions, normal spacing at the wall, etc .... If you really want to study 2D multi-element wing profiles, perhaps MSES (big brother of XFoil) is the code to use. That will give you far better drag values.
Old   February 17, 2004, 17:39
CFD Rookie
I have been looking for MSES all over the internet but I couldn't find any .exe files. Is this MSES free like Xfoil (I do have Xfoil).
I know it is very difficult to get the correct Cd. But I also have problem getting the lift. Right now I am trying to model NASA LS0417 airfoil (in NASA TN D 7428). I am starting the modeling of the airfoil from 0 degree up to 16 degree alpha. At high alpha case, I can only get about 50% of the lift because the high pressure gradient at leading edge suction side is so grossly underpredicted. All my pressure side Cp vs x/c on the other hand has good agreement with the paper. Anyone out there who has experience in this type of modelling please give me some help. Besides keep on increasing the mesh count right around the leading edge there seems to be nothing else I can do, but the suction side pressure is still under estimated by alot.
Thanks for the help in advance.
Old   February 18, 2004, 01:29
Charles Crosby
MSES is not free, except possibly for academic research purposes. Best plan is to contact Mark Drela (author of the program) at MIT directly. Are you at least getting the lift at zero angle of attack and the lift curve slope at small angles of attack right? At high angles of attack the choice of turbulence model may become quite important, the standard k-epsilon model would typically be a bad choice!
Old   February 18, 2004, 09:36
CFD Rookie
At this point, for alpha = 0 degree, I can only get about 50% of the Cl (pretty much the same as alpha = 16 deg case, about 50-60% Cl). So what are the catches for this type of problem. Before modelling this NASA LS airfoil, i also tried to model NACA 2415 and clark Y airfoil, and I get almost perfect match at low alpha and about 90% Cl at alpha near stall. But for this new NASA airfoil (not really new, 1973) I am really puzzled at the result. Can you please give me additional guildlines?
by the way, I am aware of the fact that standard k-epsilon can't deal with recirculation well, that's why it is a bad choice for high alpha cases, but at low alpha cases where there is no separation at the suction side or trailing edge, do you think k-e still good?
Old   February 19, 2004, 02:31
Charles Crosby
You may want to focus some attention on the trailing edge area rather. The LS(1)417 is a slightly bizarre airfoil, in the sense that it is very heavily aft loaded, and if you don't get the flow at the TE right you won't get the "suction" right either. That thick trailing edge needs to be modelled as well. This is to me an interesting topic, but maybe it should be continued by e-mail. Contact me at charles.crosby "at" kentron.co.za , replace the "at" symbol with the usual @ (trying to avoid spam here ;-) )
Old   September 18, 2009, 05:47
Default Important
Prashant Kumar
cfd.aero.soam is on a distinguished road
hi Charles crosby
I am Prashant from India. I am working in National Aerospace Laboratory. I have created mesh over multielement airfoil in Gambit and now i am using Open Foam as solver. At M=.2 and 0 AOA. In solving I dont knoew hou to converge solution .Please give me your guidence and some tutorials ,which i can follow in this regard.
Prashant Kumar
cfd.aero.soam@gmail.com
cfd.aero.soam is offline   Reply With Quote
Old   September 18, 2009, 05:48
Default imprtant
Prashant Kumar
hi Rookie
Prashant Kumar
Old   October 29, 2013, 21:10
Kaptmndo
wanfuhh is on a distinguished road
hello sir, can i have the example of file for analysis using fluent that u said before? i would really appreciate it. here is my email. wansyahmi17@gmail.com
wanfuhh is offline   Reply With Quote
Old   October 31, 2013, 16:02
Totalsim's Avatar
Jon
Totalsim is on a distinguished road
This may sounds silly but have you represented the geometry accurately? It may be something as simple as the blockage ratio.
TotalSim CFD Engineer
www.totalsimulation.co.uk
Totalsim is offline   Reply With Quote
Old   November 17, 2016, 06:07
Nader Nekoubin
NaderNekoubin is on a distinguished road
Send a message via Skype™ to NaderNekoubin
you may have three possible mistakes. 1: solving the main equation including of Navier-Stokes and energy equations wrongly. in this condition, you can check the whole procedure. 2: calculating the cl and cv wrongly. in this condition, you can first check the contours for velocity and pressure around the airfoil with experimental and numerical results in the literature to ensure about the solution; then you can check the formulas for cl and cd calculation. 3: the quality of used grid. it has little possibility, but using a very "bad" grid can cause such deviation from the actual and valid results. check the mesh!
NaderNekoubin is offline   Reply With Quote
Problem running simpleFoam on a multi element airfoil vinz OpenFOAM Running, Solving & CFD 18 April 11, 2013 11:26
Question about reference values --> Area (multi element wing) Zweeper FLUENT 7 March 28, 2010 11:29
y+ for Airfoil Analysis asd Main CFD Forum 3 April 18, 2007 10:54
multi element airfoil data shadi memarpour Main CFD Forum 0 June 20, 2004 04:33
Multi Element Airfoil J.Dumas Main CFD Forum 2 May 13, 2000 07:24
