FVM(MATLAB) code for the circular fin(conduction) problem
1 Attachment(s)
Dear All
I have some problem in FVM code please help me for the particular case i want to do k(thermal conductivity) and A(cross-sectional area) should be constant in circular fin. close all clc %specify the number of control volumes n=5; %number of control volumes maxiter=200;%maximum iteration number np1=n+1; np2=n+2; np3=n+3; %%define calculation domain tl=1; %total length of the cylinder delx=tl/n; dx=ones(1,np2); dx=delx*dx; %replace fictitious boundary volume size dx(1)=1.0e-10; dx(np2)=1.0e-10; %assign x-coordinate x(1)=0; for m=1:np2 x(m+1)=x(m)+dx(m); end %define cross-sectional area dia=0.25; for i=1:np3 ac(i)=pi/4*dia^2; %constant cross section end %prescribe intitial temperatures for all control volumes for i=1:np2 te(i)=100; tep(i)=te(i); end %iteration for convergence iter=0; iflag=1; %iteration loop for the convergence while iflag==1 % end is at the end of program ********* %prescribe thermal conductivity for i=1:np2 tk(i)=1; end %prescribe boundary temperature te(1)=100;%at the left boundary given temperature hf=0.2;% right boundary given flux tf=20; te(np2)=te(np1)-hf*(te(np2)-tf)/(tk(np1)/... (.5*dx(np1))); % te(np2)=100; %initialize the coefficients for tdma matrix %evaluate the diffusion conductance and source terms for i=2:np1 % diffusion conductance ke=tk(i)*tk(i+1)*(dx(i)+dx(i+1))/... (dx(i)*tk(i+1)+dx(i+1)*tk(i)); de=2.0*ke*ac(i+1)/(dx(i)+dx(i+1)); ae=de; kw=tk(i)*tk(i-1)*(dx(i)+dx(i-1))/... (dx(i-1)*tk(i)+dx(i)*tk(i-1)); dw=2.0*kw*ac(i)/(dx(i-1)+dx(i)); aw=dw; %source term evaluation % sp=-1600; % sc=4.768e5; per=pi*dia; sp=-hf*per/ac(i); sc=hf*per/ac(i)*tf; ap=ae+aw-sp*dx(i)*0.5*(ac(i+1)+ac(i)); b=sc*dx(i)*0.5*(ac(i)+ac(i+1)); %setting coefficients for tdma matrix ta(i)=ap; tb(i)=ae; tc(i)=aw; td(i)=b; %modify using boundary conditions if i==2 td(i)=td(i)+aw*te(1); elseif i==np1 td(i)=td(i)+ae*te(np2); end end %solve the simultaneous equations by using tdma nq=n; nqp1=nq+1; nqm1=nq-1; %forward substitution beta(2)=tb(2)/ta(2); alpa(2)=td(2)/ta(2); for i=3:nqp1 beta(i)=tb(i)/(ta(i)-tc(i)*beta(i-1)); alpa(i)=(td(i)+tc(i)*alpa(i-1))/... (ta(i)-tc(i)*beta(i-1)); end %backward substitution dum(nqp1)=alpa(nqp1); for j=1:nqm1 i=nqp1-j; dum(i)=beta(i)*dum(i+1)+alpa(i); end %end of tdma %update the temperature for i=2:np1 te(i)=dum(i); end %check the convergence for i=1:np2 errote(i)=abs((te(i)-tep(i))/te(i)); end error=1.0e-6; if (max(errote)>error) iter=iter+1; tep=te; iflag=1; else iflag=0; end if iter>maxiter break end end % this end goes with the while iflag==1 at the top******** %compare with exact solution to make sure program works correctly %locate the midpoint of control volumes for i=1:np2 xc(i)=0.5*(x(i)+x(i+1)); end % m=sqrt(hf*per/(tk(1)*ac(1))); thetab=te(1)-tf; for i=1:np2 theta(i)=(cosh(m*(tl-xc(i)))+hf/(m*tk(1))*sinh(m*(tl-xc(i))))/... (cosh(m*tl)+hf/(m*tk(1))*sinh(m*tl)); end theta=thetab*theta; teexact=theta+tf; teexact=teexact' %print the results fprintf('iteration number is %i \n',iter) disp('circular fin temperatures are') fprintf('%9.3f \n',te') %plot the result xc.vs.te plot(xc,te,'-',xc,teexact,'--o') grid on title('circular fin temp'),xlabel('x(m)'),ylabel('T(C)') legend('numerical solution','analytical solution') Temperature Output 100.000 86.537 68.128 55.880 48.224 44.180 43.706 the exact solution temperature are T1=64.22 T2=36.91 T3=26.50 T4=22.60 T5=21.30 in plot delta x is upto 1.4 this should be 1m thank you |
