How to simulate the heat transfer of a heat sink by a vibrating blade.
Hi,everyone. A weird problem appeared when i simulate the heat transfer process of a heat sink by a vibrating blade.
1. Create a 3D model in CATIA V5R19, and saved it in .model format. 2. Read the model in ICEM and generate a grid. 3. Read the mesh into Fluent. I set the fluid as air; the heat sink as aluminum;the blade has no thickness; other boundary are set as pressure in or out. But after I finished initialization , it can't allow me to save the Case&Data. The Error message like this: Host receiving summary from compute node zero. Writing "C:\Users\LXJ\Desktop\HS\C\fluent.dat"... turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 479944 cells Primitive Error at Node 0: Cell_Function_Values: No post-processing value exists. Primitive Error at Node 2: Cell_Function_Values: No post-processing value exists. I am not sure how to carry out this problem. Thanks in advance |
