December 13, 2016, 01:25 |
Kiva compiling
sajad
Rep Power: 11 |
I have tried many compilers to compile kiva3v code but for each compiler I face different errors. For example for g77 compiler, I use this make file for compiling code :
#makefile for the program KIVA3 for the H-P, 012296/1435 FC= g77 FFLAGS= -c LD= g77 all: kiva3 k3prep k3post kiva3 : kiva3.o utility.o second.o $(LD) -o kiva3 kiva3.o utility.o second.o second.o : second.f $(FC) -c +U77 +DA1.0 second.f utility.o : utility.f $(FC) $(FFLAGS) utility.f k3prep.o : k3prep.f $(FC) $(FFLAGS) k3prep.f k3post.o : k3post.f $(FC) $(FFLAGS) k3post.f kiva3.o : kiva3.f $(FC) $(FFLAGS) kiva3.f kiva3.f : comkiva.i comfuel.i touch kiva3.f k3prep : k3prep.o second.o $(LD) -o k3prep k3prep.o utility.o second.o /usr/local/lib/libcgsdbl.a k3prep.f : comprep.i touch k3prep.f k3post : k3post.o utility.o second.o $(LD) -o k3post k3post.o utility.o second.o /usr/local/lib/libcgsdbl.a -lX11 k3post.f : compost.i touch k3post.f Unfortunately, I encounter this error : g77 -c kiva3.f kiva3.f: In subroutine `chem': kiva3.f:192: data pi /3.14159 26535 89793 23846/ 1 kiva3.f:4481: (continued): data capa, capb / 18.0 , 0.5 / 2 Common block `kiva8' initialized at (2) already initialized at (1) -- only one program unit may specify initial values for a particular common block kiva3.f: In subroutine `setup': kiva3.f:17368: warning: 1 'the cylinder wall') ^ Missing comma in FORMAT statement at (^) kiva3.f: In subroutine `wallfilm': kiva3.f:25938: warning: if(impinge.eq.1) call spread ^ Reference to unimplemented intrinsic `SPREAD' at (^) (assumed EXTERNAL) nmake3:24: recipe for target 'kiva3.o' failed make: *** [kiva3.o] Error 1 Could anybody explain why I get this error? |
[OpenFOAM.org] Trouble Compiling OpenFOAM-dev using Intel Compiler 15 for use on Xeon Phi | foamer123 | OpenFOAM Installation | 9 | August 20, 2015 14:03 |
Help with KIVA4 source code compiling | geothokar | Main CFD Forum | 0 | September 3, 2010 05:40 |
mesh converter in KIVA 4 | DaIN | Main CFD Forum | 0 | June 7, 2010 12:54 |
KIVA Errors | Ravi Kiran | Main CFD Forum | 0 | February 23, 2006 06:42 |
PDF - conserved scalar approach in KIVA | vega | Main CFD Forum | 0 | July 5, 2005 02:49 |
