Characteristic length for the Grashof number in a tank with small horizontal heaters
Old   December 27, 2016, 11:21
Default Characteristic length for the Grashof number in a tank with small horizontal heaters
Saeb
sbesarati is on a distinguished road
Dear friends,
I am working on heat transfer simulation of a tank filled with liquid salt using Fluent. The tank is cylindrical and there are four cylindrical heaters penetrating from the side walls to the tank (perpendicular to the side walls). The size of the heaters are much smaller than the size of the tank. I am trying to model natural convection inside the system. Only 1/4 of the geometry is modeled and periodic boundary condition is used to simulated the remaining 3/4 of the geometry.
The question I have is that for calculating the Grashof number which characteristic length should I use? If the height of the side wall is chosen, the flow is turbulent. Another approach is to only use the diameter of the cylindrical heater, which results in a laminar flow. I really appreciate if you could please help me in this regard.
Thanks
sbesarati is offline   Reply With Quote
Old   December 27, 2016, 11:26
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by sbesarati View Post
Dear friends,
Thanks
What you are evaluating is correct, two different values for the Gr numbers that depend on two different lenghts. Both are correct. That said simply that you must consider that laminar, transitional and turbulent flow condition can cohexist in your flow problem.
FMDenaro is offline   Reply With Quote
Old   December 27, 2016, 16:34
Saeb
Thanks for your reply.
Then, the question is which model I should use to simulate this problem, laminar or turbulent?
Old   December 27, 2016, 18:57
laminar is not a model....
think first about the best formulation you can adopt for the physics of your problem (DNS/LES/RANS)
flow regime, fluent, grashof number, heat transfer, natural convection
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 18:32
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
characteristic Length CFD MAN Main CFD Forum 3 September 11, 2002 07:26
Characteristic Length CFD MAN FLUENT 0 August 19, 2002 21:40
Characteristic Length Scale Thomas P. Abraham Main CFD Forum 2 April 20, 1999 17:16
