March 9, 2017, 05:14 |
Mesh refinement thickness
badoumba
Rep Power: 12 |
Hi guys!
For external aerodynamics, if we are only interested of analyzing surface pressure, would it be enough to fine mesh the boundary layer? Beyond this zone is only freestream after all. It is easy to calculate this layer thickness. For the case I have (a 2m object at 60m/s), it's only 6mm. This could save a lot of cells! Thanks |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
[snappyHexMesh] Bad/jagged mesh around intersection of two .stl bodies | MBttR | OpenFOAM Meshing & Mesh Conversion | 7 | October 14, 2016 03:57 |
[snappyHexMesh] How to Do External Mesh for Airfoil sHM | msuaeronautics | OpenFOAM Meshing & Mesh Conversion | 1 | September 23, 2012 04:00 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
