How to calculate swirl velocity or angular velocity in a in-cylinder flow analysis us |
February 23, 2016, 10:07 |
Gomathi shankar
I am doing an in-cylinder steady state flow analysis. In that I need to calculate the angular velocity of air rotating
about the cylinder axis. I have been using a custom field function to monitor the velocity. The field function is given as: (x*Vz-z*Vx)/(x*x+z*z). While using this field function the velocity fluctuates between a maximum and minimum valve. It does not settle or converge even the solution is converged. I need to know whether the field function is correct or wrong? Why the value fluctuates? I really need this explanation which will help me in my project work. If anybody experienced this same issue, please let me know. Thanks in advance. |
February 23, 2016, 12:25 |
Matt
Rep Power: 17 |
Depending on what software you are using, you can probably setup a cylindrical coordinate system and then treat it just like x y z components except get axial, tangential and radial flow velocities.
April 26, 2017, 16:55 |
Curl of the velocity field
Muhammad Zahid
cylinder flow, swirl, swirl ratio |
how to give swirl flow in 3D cylinder by using fluent 6.3 | shivampm | FLUENT | 4 | January 28, 2019 04:52 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
Appropriate flow velocity for basic 2d analysis | Lukasz Mosakowski | FLUENT | 1 | February 14, 2006 08:58 |
In a swirl flow, how to show tangetial velocity | Wang | FLUENT | 1 | October 27, 2000 03:59 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
