How To Simulate Flow With Really Close Multiple Rotating Parts Comsol |
November 14, 2018, 19:42 |
Gustavo Assad
Hi !
I want to simulate the gas flow inside a rotary engine. Please see the picture for better understanding. Comsol 1.jpg It has 3 rotors, where the central one has teeth-like parts that compress the gas in the cavities of the side rotors. So it appears that the rotating domains will overlap. I want to simulate this model to see where is the best places for inlet and outlet locations. However, I'm new to consol so even the 2d simulation is giving me trouble. How should I configurate the rotating domains, and meshing ? Is there a tutorial with a similar example ? Because I haven't found a example that uses interchanging teeth with flow between them. Comsol 2.png Obs.: I use Solidworks for the Geometry. Thank you very much ! |
comsol 5, rotary engine, rotating boundary, rotating mesh |
Display Modes | |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
VISCOUS DISSIPATION at the rotating flow | gaishiwushuang | STAR-CCM+ | 2 | May 4, 2018 13:44 |
How to simulate a flow field where a rotating object travelling? | SJSW | ANSYS | 0 | July 22, 2014 01:25 |
dynamic meshing-effect of rotating parts on flow | rahul | FLUENT | 0 | August 5, 2006 22:10 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
