June 7, 2017, 12:31 |
Calculating frictional losses in cd nozzle
Justin
Rep Power: 11 |
Hi all,
I'm analyzing rectangular, single expansion ramp, converging-diverging nozzles and I'd like to determine what the frictional losses are. I'm using ANSYS software (DesignModeler, Meshing, Fluent, and CFD-Post). So far I've searched this forum, as well as Google, and have come up dry. Maybe I'm not searching the correct terms...anyways... I have 4 nozzles that I ran at 3 nozzle pressure ratios (NPRs) and I'm wanting to compare them to determine the best performing nozzle. Thus far to compare nozzles I've computed: 1) entropy rise between inlet and outlet 2) discharge coefficient (ratio of actual mass flow rate to ideal mass flow at the nozzle throat) 3) exit velocity coefficient (ratio of actual exit flow velocity to ideal/isentropic exit flow velocity) 4) and gross thrust coefficient (ratio of actual thrust to ideal/isentropic thrust) To better determine why one nozzle performs better than the others, I'd like to compute the frictional losses. I'm not quite sure how to do this using CFD-Post, let alone what equation(s) I can use to determine frictional losses. If someone could throw me a bone on where to look for more information on this topic, it would be greatly appreciated! Note that I've been mass flow averaging all quantities. Thanks, Justin |
June 7, 2017, 21:57 |
#2 | |
Lucky
Rep Power: 65 |
Wall shear stress and total pressure drop.
2), 3), and 4) look nice on paper, but "ideal" and "isentropic" conditions are very subjective. Usually these ideal conditions are determined with another dozen assumptions, like constant properties, or one-dimensional flow, or even incompressible flow. Regarding 4) there is a variable called the stream thrust which gives you the potential thrust of a stream. The stream thrust combines the roles of momentum and pressure and plays a similar role to enthalpy in combining internal energy and pressure. |
June 8, 2017, 11:31 |
Justin
Rep Power: 11 |
Thanks for the reply. Regarding gross thrust coefficient, I determined that by actual and ideal thrust:
where is the coefficient of velocity in the axial direction, is the total enthalpy, and is the nozzle pressure ratio. Doesn't the above account for the quantities you're referring to? I tried Googling "stream thrust" and everything I've found so far refers to general thrust. Could you point me in the right direction? |
June 8, 2017, 19:23 |
Lucky
Rep Power: 65 |
You more or less have it. Stream thrust is given by:
Notice you don't subtract the ambient pressure. The reaction force is the difference in the stream thrust between the inlet and outlet. The reason this is important, is that there is thrust at the inlet stream into the nozzle. This thrust comes from the inlet stream and not the acceleration due to the C-D itself. So if you optimize based on thrust at the outlet instead of the thrust generated by the nozzle, you will get slightly different (non-optimal) C-D nozzle design. The problem with isentropic thrust is, the formula used to calculate the isentropic thrust normally assumes all the things I mentioned before, which is unrealistic for a real nozzle. For example: assumes you have a ideal gas with all constant properties. Same thing with ideal flow rate. But 90-99% of people you work with are not aware of these shortcomings and they think the ideal flowrate is what you'll actually get if your nozzle is isentropic. Sometimes it's more important to speak the same language than to use the correct words (i.e. political correctness). |
Calculating thrust for a rocket nozzle for a biphasic fluid | toniatop | CFX | 0 | January 17, 2013 19:15 |
Doubt about calculating the frictional velocity over an airfoil | Jorg | FLUENT | 1 | November 14, 2012 00:32 |
Frictional losses at wall | Sans | CFX | 1 | May 23, 2008 04:09 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
