Level Set Method and Immersed Interface Method |
July 7, 2017, 02:37 |
Jun
Rep Power: 10 |
Dear all,
I am a master course student who is currently doing research using Immersed Interface Method and Level Set Method. Now, I am trying to represent my surface with signed distance function. I can calculate the minimum distance easily, but I don't know how to determine whether the grid point is inside or outside of the surface. I have searched about the method but usually they gave me a simple example like circle which can be represented with exact function. Specifically, I want to know how to get the initial level set function with discrete surface control points. Is there anyone who can help me? Jun |
August 5, 2017, 11:48 |
Rep Power: 15 |
In the level set method the distance function is a signed function. If it is positive you are in fluid 1 (inside the surface), if it is negative you are in fluid 2 (outside the surface). Of course it depends on the way you initialized this function according what is for you inside or outside or (fluid1 or fluid 2). Leflix |
August 5, 2017, 12:31 |
There is a variety of methods. The basic one uses raytracing, but you need a smart data structure for your surface. What method do you use for your distance calculation? There are chances that you can use that with a simple check to also determine the side.
level set method |
On the immersed boundary method | sbaffini | Main CFD Forum | 31 | December 5, 2019 04:39 |
implementation of the Immersed Boundary Method | mi_cfd | Main CFD Forum | 19 | April 24, 2019 01:24 |
[ImmersedBoundary] Immersed Boundary Method | DoQuocVu | OpenFOAM Community Contributions | 11 | July 13, 2018 09:36 |
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM | keepfit | OpenFOAM | 4 | January 31, 2014 14:32 |
smoothed interface capturing method: compressible. | jinwon | Main CFD Forum | 0 | May 14, 2007 00:20 |
