Does the heat transfer coefficient changes with system pressure? |
June 12, 2017, 01:50 |
Rep Power: 9 |
Hello everybody,
I was in discussion with some people about the influence on system pressure on the heat transfer coefficient. Some say that pressure has an influence on the boundary layer and therefore also on the heat transfer coefficient. Is that true and is there a relation? When calculating heat transfer coefficients, I usually choose the Gnielinski equation with Konkanov coefficient but I do not see where to adapt the pressure there. Best regards h0rst |
June 12, 2017, 09:36 |
Jim Breunig
Rep Power: 8 |
Conceptually, I could see how pressure could effect heat transfer. Higher pressure means molecules are closer together, which could change heat transfer rate. So really, density is the effect. I don't have my book in front of me right now, but I imagine density should come into play since it's in Reynolds and Prandtl numbers.
June 13, 2017, 01:51 |
Rep Power: 9 |
Thank you for the answer.
I would also think that the higher pressure has an influence only on the density, so if we use an incompressible fluid like water, this influence would be very small and hardly measurable when we are in a range of approximately 1-10 bar. Best regards h0rst |
June 13, 2017, 08:15 |
Jim Breunig
Rep Power: 8 |
No problem. I would agree that pressure would not have an effect with water in the pressure ranges that you're dealing with.
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 17, 2014 23:45 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
