Cases to be suggested
I am developing a solver for two dimensional turbulent, isothermal, non-reactive single phase flow in general domains
Could you please suggest for me some cases/papers for that type of flow as I need to verify my code ?, particularly the experimental cases. Thank you |
I would suggest:
HTML Code:
https://turbmodels.larc.nasa.gov/index.html HTML Code:
https://cfl3d.larc.nasa.gov/Cfl3dv6/cfl3dv6_testcases.html |
If you are using a 2d model then you are using RANS, thus you should be aware of how the experimental measurements are averaged to be congruent to the solution. I suggest to start with the backward facing-step flow.
Try to search also in the AGARD test cases |
