Y+ around a cylinder
Old   July 4, 2017, 09:10
Exclamation Y+ around a cylinder
Zeinab
Zeinaby is on a distinguished road
Hi everyone
I'm trying to optimise the mesh in my Fluent model. That is a "flow past cylinder" model. I modelled a half block of the whole simulation domain with defining the symmetry boundary conditions.
I checked the Y+ contour after a transient simulation for the half block model. The solution converged very well (with K-W SST turbulence model). The Y+ contour image is attached. But I'm not sure how I should analyse that.
1- Is it Ok to have Y+ value out of accepted range (30<Y+<60) far from the walls?
2- Is it OK to have Y+ value equal to 0 at the pier wall and symmetry boundaries? If not, how I could increase the Y+ value at the cylinder wall where I need very fine mesh to solve the boundary layer?
Any help/advice is greatly appreciated.
Zeinab
Zeinaby is offline   Reply With Quote
Thread Tools
Trackbacks are On
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 3 April 15, 2016 08:29
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 17:16
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 06:01
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
