March 29, 2005, 08:53 |
Inverted cells with Kiva3
I am trying to create a mesh of a real diesel engine, with inlet ports, exhaust valve and bowl. The mesh created with k3prep looks fine, and k3prep does not report any inverted nor not-convex cells. When I start the simulation with kiva3, at the very beginning, I obtain a report of many non convex and inverted cells, which obviously stops the simulation. Which is the cause? Are there some general guidlines on how the kiva mesh should loock like?
March 30, 2005, 03:41 |
Re: Inverted cells with Kiva3
I am sorry I can not help you with meshing. I thought that you have some problems in comiling the code which I may be able to solve. Sorry
June 15, 2017, 13:54 |
#3 | |
Hossein Keshtkar
KIVA-3V works with Multiblock structured volumetric meshes. I used ANSYS- ICEM to generate mesh grids for KIVA-3V |
[snappyHexMesh] Number of cells in mesh don't match with size of cellLevel | colinB | OpenFOAM Meshing & Mesh Conversion | 14 | December 12, 2018 08:07 |
[snappyHexMesh] sHM too many cells | Knapsack | OpenFOAM Meshing & Mesh Conversion | 2 | July 8, 2017 07:41 |
[snappyHexMesh] snappyHexMesh matches wrong cells to CellZone | Siegunn | OpenFOAM Meshing & Mesh Conversion | 4 | July 31, 2015 05:10 |
[snappyHexMesh] snappyHexMesh Segmentation Fault | avd28 | OpenFOAM Meshing & Mesh Conversion | 11 | May 11, 2015 20:32 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
