Laminar flow between parallel plates with SIMPLE algorithm |
November 18, 2016, 14:21 |
Alper
Rep Power: 12 |
Hello Folks,
I'm trying to code in FORTRAN incompressible laminar flow between two parallel plates. I put uniform inlet velocity. I use finite volume method. I'm using 1-D convection-diffusion equation and representing it by the power law. I'm linking velocity and pressure fields using the SIMPLE algorithm. Dimensions of the channel are Length x Height is 2x0.02. Reynolds number is 150. So my question is, I need to divide this domain to 160x40 control volumes but when I do it, solution blows up. When I divide domain to 40x160 it runs without any problems. So I wonder if anyone has any comments why Length (2m) cannot be divided into 160 control volumes. |
July 19, 2017, 01:02 |
Alper
Rep Power: 12 |
It's been a long time I forgot about this thread.
Just in case if anyone will have the similar problem I solved the problem. I realized that in the first few iterations solution was not propagating to the end of the channel when I was dividing length to the 160 meshes. Solution is to add global mass conservation to the code which basically forces mass to be conserved for the first few iterations until solution reaches to the end of the channel. Global mass conservation added to the code by checking if the ratio of total outlet mass to the total inlet mass is equal to 1 after each iteration. If not, it is forced to be. Sent from my iPhone using CFD Online Forum mobile app |
convection-diffusion, laminar flow, parallel plates, simple |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Setting boundary conditions for simple pipe flow with flow direction changing in time | Sipher | FLUENT | 1 | May 4, 2015 20:05 |
Is it a turbulent flow or laminar flow? | ringtail | Main CFD Forum | 9 | January 22, 2015 19:52 |
SIMPLE algorithm for variable density flow | mauz | Main CFD Forum | 1 | May 15, 2009 15:13 |
Solve Simple foam for laminar flow | nandiganavishal | OpenFOAM Running, Solving & CFD | 4 | January 20, 2009 00:56 |
