Solution converged differently
Old   July 20, 2017, 08:19
Default Solution converged differently
Delhi
aviral2000 is on a distinguished road
Hi everyone,
I am beginner in field of development of CFD codes. I was trying out the example given in "A introduction to Computational Fluid Dynamic" by Versteeg and Malalasekra. I made a python code for a 2D heat transfer solver using TDMA approach. I started by directly entering the values given in the example ( will do the derivation of the coefficients from system parameters later). In the solution given in the book, my first iteration result is matching, however my converged solution is completely different. It would be great if someone could advise me on where I could have gone wrong or how to improve the solution?
aviral2000 is offline   Reply With Quote
Old   July 20, 2017, 11:15
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by aviral2000 View Post
Hi everyone,
Check you program, it is likely you have some error. Furthermore, I suggest to post the plot of you solution.
FMDenaro is offline   Reply With Quote
Old   July 20, 2017, 13:32
Delhi
Thanks for your reply. I rechecked my program, and I found that I made a mistake while defining the coefficient matrix. The problem is solved, thank you. Can you tell me about some open source codes in python which I could consult to accelerate my learning process?
Thank you
Old   July 20, 2017, 19:38
Michael Prinkey
mprinkey will become famous soon enough
Thank you
I've posted this here many times before, but this is a great way to get started with CFD using Python:
http://lorenabarba.com/blog/cfd-pyth...navier-stokes/
mprinkey is offline   Reply With Quote
Old   July 21, 2017, 01:23
Delhi
Thanks for this link. I have gone through it earlier, it's too basic. I am able to code more complex codes by myself. I wanted to get hold any easy to understand 2-D navier stokes solver solving structured grid (not very simple geometry like in the link you posted) or with unstructured grid.
Thanks
Thread Tools
Trackbacks are On
Strange results in converged solution Pastukhov CFX 5 January 16, 2017 01:52
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 0 June 22, 2016 08:26
Why the solution could only be converged in aestas FLUENT 11 October 20, 2015 04:31
solution is not getting converged Nijanthan FLUENT 5 July 25, 2013 01:42
simple solution converged in 9 iterations? Gabbee90 OpenFOAM Running, Solving & CFD 0 August 6, 2011 23:53
