July 21, 2017, 13:11 |
Implementing Richardson Extrapolation
I have a set of data for radius as a function of time. Please note that I do not have the expression of the function, I only have the values of radius at a given time. I want to implement Richardson extrapolation to these values using MATLAB. I am not sure, how to go about writing the code. Because most of the examples are using an expression as in "y=f(x)". Any help would be appreciated. Thanks. |
July 21, 2017, 17:05 |
Lucky
Rep Power: 65 |
July 21, 2017, 17:15 |
#3 | |
Thanks for your help. |
July 21, 2017, 17:34 |
Lucky
Rep Power: 65 |
h is the step-size
For example, if you want to R(t1), R(t2), R(t3) and want to extrapolate to R(t4) then h is delta in t (t2-t1, t3-t2, etc). k is the ratio deltas which is often 2 for uniformly sampled data. n is the order of convergence which you should already know. If not, you have to estimate n using another technique. |
July 22, 2017, 11:23 |
[ICEM] Export mesh statistics for use in Richardson Extrapolation for grid sensitivity study | JuPa | ANSYS Meshing & Geometry | 13 | July 5, 2018 08:35 |
ReactingFoam (w/ k-omega-SST): Error analysis using Richardson Extrapolation | JMDag2004 | OpenFOAM Verification & Validation | 1 | June 10, 2015 12:33 |
Richardson extrapolation | pc | Main CFD Forum | 11 | March 8, 2013 06:50 |
Richardson Extrapolation to check time and space convergence | Hooman | Main CFD Forum | 0 | December 29, 2010 08:19 |
Richardson extrapolation | cynthia | FLUENT | 4 | June 20, 2008 08:58 |
