Is there code to plot stream function from u & v velocities
Like Tree5Likes
Old   August 6, 2017, 08:13
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
Originally Posted by leflix View Post
First how many points do you have in x direction (i) and in y direction (j) ?
I opened the file in excel and it clearly shows that its in i direction its 4624 (reaches end of file) and in y direction just 4 because I have 4 columns (j is loop for the variables which are x,y,u,v)
kbaker is offline   Reply With Quote
Old   August 6, 2017, 08:38
leflix is on a distinguished road
no what you read is the total number of nodes.
Imagine NI (number of nodes in I direction) is 20 and NJ ((number of nodes in J direction) is 45. Then you will have 900 total number of grid points.
this corresponds to your 4624
leflix is offline   Reply With Quote
Old   August 6, 2017, 09:09
kbaker's Avatar
Khalid Baker
My data consists of 4 columns each column has 4624 point please look to the the excel file I was uploaded it.
Old   August 6, 2017, 09:35
yes but it is not what I asked you. First you need to understand that in a 2D structured grid each node is referred to a couple of indice (i,j) ranging from 1 to NI and 1 to NJ respectively. Then you have a total number of nodes NI*NJ whhich correspond to the number of lines of you excell or .txt file.
Now if you want to use Tecplot you need to give him some information such as NI and NJ, the coordinnates of each point X(i,j), Y(i,j) and then the velocity componnents on each of these node U(i,j) and V(i,j). If you d'ont have these information you cannot use Tecplot.Having the total number of nodes (4624) is not sufficient.
kbaker likes this.
Old   August 6, 2017, 12:27
kbaker's Avatar
Khalid Baker
Now if you want to use Tecplot you need to give him some information such as NI and NJ, the coordinates of each point X(i,j), Y(i,j) and then the velocity components on each of these node U(i,j) and V(i,j). If you don't have these information you cannot use Tecplot.Having the total number of nodes (4624) is not sufficient.
Sorry for the misunderstanding. The number of nodes in x direction is 67 and in y direction is 67 . I am not too familiar with programing so I do not know how to start with the steps you mentioned and redefine the data into each node to let can be used in Tecplot?
Old   August 6, 2017, 16:15
I guess it is rather 68 and 68 as you have 4624 points
Old   August 6, 2017, 16:29
kbaker's Avatar
Khalid Baker
As I understood from your reply I need now to convert the 4624 values of each variable in my txt file into (68*68) matrix ? Hence I need to save each variable in single file then I need four files in Tech plot? right? I will be grateful if you have an illustrated program ?
Old   August 6, 2017, 16:59
kbaker's Avatar
Khalid Baker
I did it at last without need for fortran program using Tecplot but the problem legend not appear ? how I can show it?
Old   August 6, 2017, 17:03
no you don't need 4 files, only one.
Here is a program that reads tour stream.txt file and will generate the velocity.plt file to be used with tecplot.
I don't know if in your file stream.txt it should be read with
DO I
DO J
or
DO J
DO I
I don't have Tecplot on my computer presently so I cannot verify the result, but the file velocity.plt seems good excepted that the first point( x=0, y=0) is at the end of the file...
Try to understant what is done in this program
File Type: f rewrite.f (542 Bytes, 6 views)
kbaker likes this.
Old   August 6, 2017, 17:12
Kbaker you need to read the tecplot documentation or ask someone next to you who knows this kind of stuff. It is not something easy to explain tchating.
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
Simple stream function vorticity formulation for flow past a rectangle [Matlab] a99 Main CFD Forum 2 March 5, 2016 04:04
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
