Boundary conditions in open channel
Old   July 30, 2017, 12:27
Default Boundary conditions in open channel
Hector Redal
HectorRedal is on a distinguished road
I would like to know if the following boundary conditions are well possed:
Domain: rectangle
Left wall: inlet velocity (Vx, 0)
Right wall: dVx/dx = dVy/dx = 0 and P = 0.
Top and bottom walls: dVy/dy = dVx/dy = dP/dy = 0
The point is that if I run the simulation with this boundary conditions, it starts obtaining strange results, flow entering and exiting through the upper and bottom walls.
But if I use the following boundary conditions:
Left wall: inlet velocity, Vx = constant and Vy = 0
Top and bottom walls: Symetry wall, Vy = 0 (But letting Vx free)
Every thing goes smoothly (well).
So, I am wondering if the first set of boundary conditions is well posed.
Best regards,
Hector.
HectorRedal is offline   Reply With Quote
Old   July 30, 2017, 13:31
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
If I understand your nomenclature, for a 2D problem you are implicitly setting the constraint dVx/dx=0 on top and bottom. Check it.
FMDenaro is offline   Reply With Quote
Old   July 30, 2017, 16:34
Hector Redal
Yes, that it is. For an incompressible flow (dVx/dx + dVy/dy = 0), if I set the boundary condition at the bottom and at the top as dVx/dy = dVy/dy = 0, then it means that dVx/dx = 0 (dVx/dx = - dVy/dy = 0).
So, in some sense, if dVx/dx = 0 along the top and bottom domain walls, Vx does not vary along the botton and top of the domain. So in some sense it is equivalent to the second type of boundary conditions (Vx = constant, specified value).
My question is "Is this a well-posed problem"?
Old   July 31, 2017, 03:22
It depends on how do you set these conditions... For example, if you are using a projection method you have to consider the relation between pressure gradient and velocity field. I think you have some redundance and you have to properly set the BC.s for the pressure equation.
Could you give details for the setting in the momentum and in the pressure equations?
Old   August 2, 2017, 05:10
Hector Redal
Yes, I am using a projection method.
I recalled you had explained me n another thread the relation between the pressure gradient and the velocity field:
d2p/dx^2 = (1/dt) du*/dx (equation coming from Grad p = (v* -v)/dt)
In the momentun equation, I am assuming du/dx = 0 in the boundary.
In the pressure equation, dp/dx = constant (dp/dx = integral{(1/dt) du*/dx})
Old   August 2, 2017, 05:40
Your assumption provides directly d2p/dx2= 0 on the boundary
Old   August 2, 2017, 16:51
Hector Redal
But, d2p/dx^2 = (1/dt) d(v*-v)/dx, being v* the estimation of v obtained in the first step of the algorithm (where the pressure is not considered).
d2p/dx2 would be zero if the estimation of the first step is equal to the actual velocity field.
May I be wrong?
Old   August 2, 2017, 17:00
Well, if you assume du/dx=0 there is no other congruent assumption that also prescribing du*/dx=0.
Furthermore, from the continuity dv/dy=0, therefore if v=0 on the upper o lower outflow corner, it must be zero along the outflow.
Old   August 3, 2017, 10:09
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
May I ask what set of equations you are solving and what method are you using (finite volume, difference, etc.)? And what do you mean by "symmetry wall" in terms of conditions?
If you consider a classical, cell centered, finite volume scheme, your two approaches are identical from the programming point of view.
sbaffini is offline   Reply With Quote
Old   August 6, 2017, 02:55
Hector Redal
I am solving the Navier Stokes equations for incompressible fluids.
Symmetry wall: I am assuming that the velocity is parallel to the wall at that point (uy=0).
In my humble opinion, if uy=0 then duy/dy = 0, but if duy/dy=0, that does not mean that uy=0.
Old   August 6, 2017, 02:57
Hector Redal
See it this way, it is as you mention. This is something that I have overlooked.
Old   August 6, 2017, 06:05
sbaffini's Avatar
Paolo Lampitella
Consider a cell centered fv framework and a cell next to the top boundary.
Incompressible FV requires you to fix Vy and dVx/dy.
Symmetry sets both to 0.
But note that, in fv, not fixing a certain flux term really means setting it to 0.
So, the dVy/dx which is missing from above, is actually set to 0.
Analogously, the Vy that you don't set in your first bc, it is actually set to 0 in a cell centered fv framework.
So, according to the framework and how you set the symmetry, the two bc may actually end up being the same, that's why I asked.
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 18:02
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
open channel flow boundary conditions yan FLUENT 0 July 4, 2005 23:36
