Courant number or velocity overshooting; instability issue in multiphaseEulerFoam |
September 22, 2017, 09:33 |
I have found a typical problem with OpenFoam multiphase simulations. When trying to simulate with multiphaseInterFOAM, it runs well. But while doing multiphaseEulerFoam, it always results in shooting in Courant number and eventual failure.
I have 4 phases air, water, solid_phase1, solid_phase2. The last two phases having density 2600 and 4000 (higher than water). I have tried almost all possible combinations to get the simulation run but no luck. At the end (and following some reference over the internet), I can conclude that it is OpenFoam instability issue. Since there is a huge difference between the density of air and other phases. So, when momentum exchange occurs there is a velocity jump for air due to its very low density. It is noticeable that only momentum exchange calculation between phases at interface is extra in multiphaseEulerFoam when compared to multiphaseInterFoam |
September 25, 2017, 09:18 |
Rep Power: 13 |
1) I'm not sure modelling solids with standard multiphaseeulerfoam is a valid approach. How do you set the viscosities? 2) From your post it is not clear if you're pointing to some form of bug or experiencing normal running problems. Your post is very unspecific regarding the setup and your problem while running. Is the solver crashing or is it just taking it's time to solve? One can only wonder... |
October 15, 2017, 04:47 |
#3 | |
Courant Number mean: 0.000339307 max: 6375.3 deltaT = 1.45842e-17 Time = 0.01772 PIMPLE: iteration 1 MULES: Solving for alpha.air air volume fraction, min, max = 0.999865 0 1.00031 MULES: Solving for alpha.water water volume fraction, min, max = 0.000124458 0 0.92345 MULES: Solving for alpha.phase_light phase_light volume fraction, min, max = 4.05842e-06 0 0.0318035 MULES: Solving for alpha.phase_dense phase_dense volume fraction, min, max = 6.76404e-06 0 0.0511821 Phase-sum volume fraction, min, max = 1 1 1.00032 MULES: Solving for alpha.air air volume fraction, min, max = 0.999865 0 1.00031 MULES: Solving for alpha.water water volume fraction, min, max = 0.000124458 0 0.92345 MULES: Solving for alpha.phase_light phase_light volume fraction, min, max = 4.05842e-06 0 0.0318035 MULES: Solving for alpha.phase_dense phase_dense volume fraction, min, max = 6.76404e-06 0 0.0511821 Phase-sum volume fraction, min, max = 1 1 1.00032 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 Foam::dragModels::SyamlalOBrien::K(Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #6 Foam::multiphaseSystem::dragCoeffs() const at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? |
October 15, 2017, 05:05 |
Rep Power: 13 |
Can you post CheckMesh output.
October 15, 2017, 10:32 |
rial_from_simFlow2$ checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.x-ac3f6c67e02f Exec : checkMesh Date : Oct 15 2017 Time : 20:01:25 Host : "rahul-HP-Z600-Workstation" PID : 14329 Case : /media/rahul/Passport/OpenFOAM_Simulations/spiral/Attempt04/eulerFoam/mef_1.2L_Iron_trial_from_simFlow2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : libturbulenceModelSchemes.so: cannot open shared object file: No such file or directory --> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libturbulenceModelSchemes.so" Create polyMesh for time = 0 Time = 0 Mesh stats points: 1312472 faces: 2824487 internal faces: 2262400 cells: 764762 faces per cell: 6.65159 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 612300 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 152462 Breakdown of polyhedra by number of faces: faces number of cells 6 41017 7 34 8 1664 9 70808 10 36 11 927 12 22454 13 2 14 4 15 14406 18 1108 21 2 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology outlet 3713 5011 ok (non-closed singly connected) inlet 1433 2039 ok (non-closed singly connected) atmospheric_face 86207 103207 ok (non-closed singly connected) spiralExceptAtmosphericPatch 470734 486954 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.295262 -0.295262 0.5) (0.295262 0.295262 2.3) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.94719e-17 -3.23215e-16 -1.81718e-14) OK. Max cell openness = 3.71735e-16 OK. Max aspect ratio = 4.65624 OK. Minimum face area = 1.10135e-07. Maximum face area = 0.00120969. Face area magnitudes OK. Min volume = 1.13664e-10. Max volume = 2.7218e-05. Total volume = 0.112692. Cell volumes OK. Mesh non-orthogonality Max: 73.4373 average: 18.577 *Number of severely non-orthogonal (> 70 degrees) faces: 939. Non-orthogonality check OK. <<Writing 939 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 3.93696 OK. Coupled point location match (average 0) OK. Mesh OK. End |
October 15, 2017, 11:40 |
Rep Power: 13 |
So, altough it says "ok" in CheckMesh you should look at your severly non-orthogonal cells. MultiphaseEulerFoam doesn't like this and can crash. Also, try to find the Cells with high Courant number. If this doesn't help i would re-check Boundary Conditions.
October 15, 2017, 12:24 |
#7 | |
The boundary condition folder for your convenience is uploaded. Last edited by rahulksoni; October 16, 2017 at 02:38. Reason: Uploading different format of file |
October 15, 2017, 12:45 |
Rep Power: 13 |
When you used the "Co" Tool, can you try to use a Contour Plot for Co to locate the Cells?
Edit: Since you asked about the Non-Ortho Cells also. I know that after CheckMesh there should be a folder with the Cells that have high non-ortho value. There should be a way to visualize them, can not recall it exactly ho it's done atm though. Try to search the forum for .vtk and visualization. I'm sure its on here somewhere. I can not check your .tar.gz file because i'm in windows. |
October 16, 2017, 02:39 |
#9 | |
Certainly, there are regions of high velocities (top-right image) and regions of high courant number (bottom-right image). But there is a mismatch in region selection. Not all regions/cells of high velocity possess the high courant number, indicating corresponding bigger cells. Thus, Courant number would be the true indicator for the problematic cells. The second image shows the zoomed view of the problematic region. As obvious there are cells with non-orthogonality. But the question is how to get rid of them. After analyzing the snapshots following things come to my mind: 1. Is problem really because of non-orthogonal cells. Saying the same because the cells with high courant number are all hex (as list from the obvious visibility). 2. Are courant number high because these cells are smaller than their neighbors? PS: I have updated a .zip format of 0 folder in the previous post. Last edited by rahulksoni; October 16, 2017 at 05:38. |
October 16, 2017, 03:28 |
#10 | |
The essence ( the Complete list can be found in attached 0.zip folder) of boundary conditions of my case is presented below: p_rgh Code:
internalField uniform 0.0; boundaryField { inlet { type fixedFluxPressure; value uniform 0.0; } outlet { type fixedValue; value uniform 0; } atmospheric_face { type fixedValue; value uniform 0; } spiralExceptAtmosphericPatch { type zeroGradient; } } Code:
internalField uniform (0.0 0.0 0.0); boundaryField { outlet { type pressureInletOutletVelocity; value uniform (0.0 0.0 0.0); } atmospheric_face { type pressureInletOutletVelocity; value uniform (0.0 0.0 0.0); } inlet { type fixedValue; value uniform (-0.04217 -0.05622 -0.05622); } spiralExceptAtmosphericPatch { type fixedValue; value uniform (0.0 0.0 0.0); } } Code:
internalField uniform 0.0; boundaryField { outlet { type inletOutlet; inletValue uniform 0.0; } atmospheric_face { type inletOutlet; inletValue uniform 0.0; } inlet { type fixedValue; value uniform 0.92; } spiralExceptAtmosphericPatch { type zeroGradient; } } |
October 16, 2017, 05:42 |
#11 |
Rep Power: 13 |
From your BC's i can not make out anything obviously wrong.
So my guess is still the mesh. You could try non-orthogonal corrections. If you tried that already or it's not working, there is usually only one way - re-meshing. What is your meshing tool? |
October 16, 2017, 06:05 |
#12 |
Rep Power: 13 |
Maybe you can also try to make the athmosphere as a wall not as an outlet. Just as a test, if this runs well.
October 16, 2017, 07:39 |
#13 |
October 16, 2017, 07:45 |
#14 | |
Second thing is that I have closely looked into the meshing in the region where courant number is high. I can see that the meshes are really fine there (as visible in the attached snapshot (left image)). It is because of the snapping control feature that tries to smooth the joints or edges by breaking down in increased number of cells. As top surface is atmospheric patch (just to give natural condition and for air outlet, if it is there), it is not of much concern and coarser mesh near that would be completely fine. But how do I achieve it. Bottom I am pasting my snappyHexMeshDict content. What condition is govering it. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; class dictionary; format ascii; location "system"; object snappyHexMeshDict; } castellatedMesh true; snap true; addLayers false; geometry { atmospheric_face.stl { type triSurfaceMesh; simflowType stl; name atmospheric_face; includedAngle 120.0; } spiralExceptAtmosphericPatch.stl { type triSurfaceMesh; simflowType stl; name spiralExceptAtmosphericPatch; includedAngle 120.0; } } castellatedMeshControls { locationInMesh (0.05 -0.05 2.2); refinementSurfaces { atmospheric_face { level (1 1); } spiralExceptAtmosphericPatch { level (2 4); // These are min max values, refinement can go up to max if surface curvature is more than angle defined by keyword resolveFeatureAngle. See page 32 of https://openfoamwiki.net/images/f/f0/Final-AndrewJacksonSlidesOFW7.pdf } } refinementRegions { spiralExceptAtmosphericPatch { mode distance; levels ((0.010 3) (0.030 2) (0.050 1));//((0.005 3) (0.015 2) (0.03 1));122556 nCells } atmospheric_face { mode distance; levels ((0 0)); } } limitRegions { } features // Basically important for capuring the edges properly, not having much effect in current case ( { file "atmospheric_face.eMesh"; level 1; } { file "spiralExceptAtmosphericPatch.eMesh"; level 5; } ); maxGlobalCells 1000000; maxLocalCells 100000; resolveFeatureAngle 30.0;//100.0; maxLoadUnbalance 0.1; nCellsBetweenLevels 1; gapLevelIncrement 0; minRefinementCells 3; allowFreeStandingZoneFaces false; } meshQualityControls { maxConcave 120.0; maxBoundarySkewness 5.0;//10.0; minFaceWeight 0.05; maxInternalSkewness 5.0;//9.0; minTwist 0.05; maxNonOrtho 0.0;//85.0; minDeterminant 0.01; minVolRatio 0.01; nSmoothScale 10; minTriangleTwist -1.0; minVol 1.0E-20; minTetQuality 1.0E-20; minArea -1.0; errorReduction 0.9; relaxed { maxNonOrtho 5.0;///75.0; } } mergeTolerance 1.0E-06;//1.0E-4; debug 0; combinePatches true; snapControls { implicitFeatureSnap false; nSmoothPatch 5; multiRegionFeatureSnap false; nFeatureSnapIter 5; nSolveIter 50; explicitFeatureSnap false; tolerance 0.5; nRelaxIter 5; } addLayersControls { layers { atmospheric_face { nSurfaceLayers 1; expansionRatio 1.25; firstLayerThickness 0.2; } atmospheric_face_patch0 { nSurfaceLayers 1; expansionRatio 1.25; firstLayerThickness 0.2; } spiralExceptAtmosphericPatch { nSurfaceLayers 2; expansionRatio 1.25; firstLayerThickness 0.2; } spiralExceptAtmosphericPatch_patch0 { nSurfaceLayers 2; expansionRatio 1.25; firstLayerThickness 0.2; } } nMedialAxisIter 100; minThickness 0.05; nSmoothNormals 3; maxThicknessToMedialRatio 0.5; nSmoothThickness 10; nSmoothSurfaceNormals 5; slipFeatureAngle 30.0; minMedianAxisAngle 90.0; nRelaxIter 5; concaveAngle 90.0; nGrow 0; nBufferCellsNoExtrude 0; nRelaxedIter 20; featureAngle 45.0; maxFaceThicknessRatio 0.5; nLayerIter 50; relativeSizes true; firstLayerThickness 0.5; expansionRatio 1.25; layerTerminationAngle -180.0; meshShrinker displacementMedialAxis; } |
October 16, 2017, 08:12 |
#15 |
Rep Power: 13 |
Ok.
Search for nNonOrthogonalCorrectors. You can set this value in fvsolution. You can try to run it with a value 2-3 if i'm not wrong. But this usually doesn't help in situations where non-orthogonality is very high. I'm no expert in snappyhexmesh but from the glance of the dict i would try a value of 45 for maxNonortho. A value of 0 or 5 is not doable for snappy! Also a value of 85 is to high. Also please try to set either implicitFeatureSnap or explicitFeatureSnap to "true" or vice versa. |
October 31, 2017, 00:32 |
[Solved] meshing issue
#16 |
Finally, after a lot of hit and trial and help on CO utility to produce courant number, I found that it is due to improper meshing only. Actually, snappyhexMesh tries to create the fine mesh at the corners and near the edges for their proper shape recognition. Fine meshes have smaller cell length (d). And, as we know the Courant number is:
Co = U x t / d where, U is fluid velocity in the cell, t is the current timestep size and d as said is cell length. being in the denominator d creates a lot of problems. A smaller value shoots the value of Co, forcing OpenFoam to reduce the timestep size (t) for manageable converged solutions. So, the only solution was to recreate the mesh with minimal fine meshes. Moreover, the regions with fine meshes that were creating problem were not of my interest of calculation. So, I thought to recreate the mesh. As we can see from the attached first pic that Courant number is high on and near the side wall. And, it was because that side wall and bottom spiral wall were unibody causing the same snappy condition of fine mesh near the wall to apply for both of them, as seen in the left part of the second attached pic. Later, I have separated these two walls as different bodies and removed fine meshing condition near the side wall. The resulted improved mesh is shown on the right side of the second pic. |
February 3, 2021, 05:21 |
solid-solid-air Eulerian simulation using multiPhaseEulerFoam
#17 |
Dyrney
Rep Power: 14 |
Dear,
I would like to know if someone could help me with how to set up the "phaseProperties" file (in "multiPhaseEulerFoam" solver) for more than one solid phase (solid_1-solid_2-air). How to specify the continuous phase? How to set up the drag force and heat transfer? Thanks. |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 11:44 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
