Error when opening COMSOL
Old   September 26, 2017, 06:59
Default Error when opening COMSOL
thewitcher745 is on a distinguished road
Hello, I recently encountered a problem while opening COMSOL multiphysics which gave me and error, stating that an unexpected error has occured and that I should look to the end of the log file.
Here's the log file generated by COMSOL:
'.', hexadecimal value 0x00, is an invalid character.
at System.Xml.XmlEncodedRawTextWriter.InvalidXmlChar( Int32 ch, Char* pDst, Boolean entitize)
at System.Xml.XmlEncodedRawTextWriter.WriteElementTex tBlock(Char* pSrc, Char* pSrcEnd)
at System.Xml.XmlEncodedRawTextWriter.WriteString(Str ing text)
at System.Xml.XmlWellFormedWriter.WriteString(String text)
at System.Xml.Linq.ElementWriter.WriteElement(XElemen t e)
at System.Xml.Linq.XElement.WriteTo(XmlWriter writer)
at System.Xml.Linq.XNode.GetXmlString(SaveOptions o)
at Comsol.Communication.ChannelBasedCommandManager.Se ndCommand(OutgoingCommandHandler commandHandler)
at Comsol.Communication.BridgeCommandManager.Outgoing CommandHandler.Run()
at Comsol.Communication.BridgeCommandManager.RunAndWa it(BridgeCommand command)
at ComsolDesktop.MainWindow.StartJava(Boolean debug, Boolean devPlugins, NDisconnectInfo disconnectInfo, IBridgeCommandManager oldMgr)
at ComsolDesktop.App.OnStartup(StartupEventArgs e)
at System.Windows.Application.<.ctor>b__1_0(Object unused)
at System.Windows.Threading.ExceptionWrapper.Internal RealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatch When(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
So if anyone has an idea as to where this might be stemming from, any help would be appreciated. thanks in advance.
thewitcher745 is offline   Reply With Quote
Old   September 26, 2017, 10:42
Post
Ovid
Fole is on a distinguished road
It seems to be a character that it doesn't understand. Maybe a system path is wrong?
Fole is offline   Reply With Quote
Old   September 26, 2017, 11:03
Omojo
blex1 is on a distinguished road
i am new to openfoam, i want to Model Flame Lift-off for Liquid Sprays in the Constant using Volume dieselfoam solver. please can any one help me with the step by step code. thanks it is for my master project. its urgent. thanks
blex1 is offline   Reply With Quote
comsol, error, failure, hang, startup
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 19:00
How does CFX treat an opening when heat transfer is modelled? JuPa CFX 2 September 9, 2014 06:34
How to properly set up an opening in buoyancy driven problems lavoz CFX 5 July 23, 2014 07:06
Comsol - Opening valve denismaloir Main CFD Forum 0 May 4, 2012 07:49
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
