October 18, 2017, 11:26 |
Force Mach number = 1 as boundary condition
Giordana Tornow
Hello everyone!
I am using my own Matlab&C++ code to simulate a compressible reactive flow through a duct. It's modelled by reactive Euler equations in conservative form (solved by Riemann solvers), boundaries are coped with using ghost cells. I have a 1D and a 2/3D version of the code and need to use both. As an outlet condition I now need the Mach number to be equal to 1 because the fluid flows into a turbine which I won't simulate. I have seen a way to set the Mach number for subsonic conditions but M=1 seems to be considered supersonic. The fluid in the duct may be sub- or supersonic. As I have no idea how to deal with this condition I'll be grateful for any idea and help. I hope that's all the information needed to suggest a solution and thank you in advance! |
boundary condition, mach number, reactive euler, sonic |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
