SIMPLE code for 1D incompressible flow
Old   October 24, 2017, 03:25
Default SIMPLE code for 1D incompressible flow
Moulish Kommu
moulish is on a distinguished road
Hi, can any one send me the code for 1D icompressible flow using simple algorithm
moulish is offline   Reply With Quote
Old   October 24, 2017, 04:09
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
What do you mean for a "1D incompressible flow"? It is constrained by the du/dx=0 continuity equation that means you have the solution u=constant(x). Therefore you get only
du/dt+dp'/dx=0
FMDenaro is offline   Reply With Quote
Old   October 25, 2017, 01:47
Moulish Kommu
I just wanted to know the approach for coding so that i can include any source term in momentum eqn later.
code for SIMPLE algorithm - 2D Lid driven cavity flow problem - Collocated grid h_amooie OpenFOAM Programming & Development 1 January 22, 2022 12:33
Validation for a channel flow code jinhua2015 Main CFD Forum 7 December 31, 2015 13:03
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 03:19
momentum under-relaxation for compressible flow with SIMPLE Mihai ARGHIR Main CFD Forum 0 April 7, 2000 05:58
