Periodic boundary condition in spanwise direction
Hello, my friends,
I have a CFD question about periodic boundary condition in the spanwise direction. As we know, the periodic boundary condition can set for streamwise direction, so the quantities can replace from outlet to inlet and vice versa. also, in this direction, we should do a pressure correction to find the pressure drop. now, I wanna know the differences of implementing this BC in spanwise and streamwise direction. Hope to help me. |
1 Attachment(s)
my case is a channel with a 3d cavity on its wall. this cavity is far from spanwise walls (z direction). the channel figure is attached. my big problem is that I found in literature the periodic BC for spanwise. what is the problem for symmetry BC in spanwise? |
Formally, symmetry BC implies a mirror symmetry, periodic BC implies that the solution repeats itself after a proper lenght
Thank you
My last problem. You said we dont need pressure modification for periodic BC in spanwise direction. Can you say how we implement the pressure periodic BC in spanwise direction? |
